- 27 Apr 2018
Hey all,
I currently have a Thermaltake Core P5 TG edition watercooled build. Loop specs are as follows:
Hardware Labs Black Ice GTX 420mm
XSPC Photon 270 Pump Res
Heatkiller IV CPU Block
Heatkiller IV GPU Block
I really like the aesthetics of this case, but I have the following issues
1. I wish I could add more rad space
2. It is an absolute pain to work on, having to drain the entire loop every time if changing any parts etc
So I have been thinking about grabbing something like a MORA-3 external radiator, and mounting the pump/res to it outside of the case.
I was then thinking of downsizing my build to a small M-ATX, and just running the tubes in via quick-disconnects via a PCI pass through.
In my head this should give me a much easier time draining the loop and general maintenance, along with giving me more cooling capacity, while taking up less space
Are there any draw backs to this approach? Apart from the extra space for the external rad box?
Edit: Just also had a thought that I could put quick disconnects in to my existing loop, and have the Mora 3 just sat next to the Core P5 as well, I guess that is another option.
Thanks
Thanks
