Hi guys, looks like my EVGA 980ti is starting to fail on my system - I just wondered if there's any suggestions on what else I can try. Or is it time to bite the bullet and get a new card?
So the symptoms are black screens when I'm trying putting a bit of strain on anything in 3d. I use Blender for 3D modelling and I get the black screen if I try and do something too complex, and also if I try and launch Hitman I get the black screen immediately. It's OK watching videos and browsing the web.
Here's what I've done so far - happy to hear any suggestions.
Updated the GPU drivers
I've taken the OC off from my CPU and GPU and set timings etc. to default in the BIOS
I've watched the voltage monitors in BIOS to see any fluctuations - seemed stable
Taken GPU out, cleaned the connecting pins, fans, res-seated it firmly in to the MOBO. Also verified the fans are working OK
I ran memtestG80 and it finds loads of errors in random memory tests
After seeing the errors in the memory test I've tried underclocking the GPU just to see if it made any difference, but same thing when I run the tests.
So right now I'm thinking there's an issue with the memory and I'm just wondereing if there's anything to try with that? I read an article about cooking broken GPU's in the oven ?
I dunno, I'm probably not going to do that because I still have some funtionality in 2D for the time being.
As for warranty, I bought the card new in 2015 but it failed in 2017 with a similar problem. EVGA sent me this replacement which is giving me problems. Unfortunately the warranty was for 3 years from the initial purchase so I am out of warranty now.
I'd appreciate any advice/suggestions, cheers!
I dunno, I'm probably not going to do that because I still have some funtionality in 2D for the time being.As for warranty, I bought the card new in 2015 but it failed in 2017 with a similar problem. EVGA sent me this replacement which is giving me problems. Unfortunately the warranty was for 3 years from the initial purchase so I am out of warranty now.
