This is shaping up really nicely! I'm jealous as we've had builders slowly ****ing our house up for 9 weeks. Got several things I'll have to fix myself and hope the landlord pays for...
I'm a pretty novice tiler so there's plenty of tell tale signs but most are on the perimeter / in corners you either won't see or will have a silicone bead over.
Happy with the result so far but the proof will be in the pudding.. I.E when I walk on it! Done my best to try get 100% coverage with back buttering and a 10mm trowel.
I've done lots of research to try make a good job of it and lots of horror stories seem to be a result of builders having a bash at other trades... .. Such as tiling. I've got the luxury of time so can slave over each cut whereas a builder will probably try get through it ASAP.
. I keep blasting the crud out of the holes and they keep coming back.
