New to watercooling
26 May 2019
Athens, Greece
Good evening guys!
I am new to the watercooling world, and looking in the internet i saw two kits of EKBW.
The first one is
https://www.ekwb.com/shop/ek-kit-p360
and the second one is
https://www.ekwb.com/shop/ek-kit-s360
The slim series got mediocre reviews. The thing is that my Enthoo Pro M is not a very spacy case so i need a radiator for the top that is 4 cm or less. Do i need a 360 radiator? or i ccan create a loop with a slimmer radiator?
22 Mar 2009
Down town gaza/Lah'darn
360 is the amount/size of fans not the thickness!
http://www.phanteks.com/Enthoo-Pro-M.html
Does say 360/280 in both top and front but don't say thickness! Very helpful.Not.
EK have some that are mean't to be pretty good you could also put either a 120 or 140 in the rear fan but not giving much room to play with as if could put rad on the outside plumbing it in through case that way out of the way and could be thick!
On my case it has two holes above fan so can put connections through which has have a 120mm lying around going to bolt on outside with fan on inside have 30mm extensions to go through then put compression fittings on ends.
Not sure what your cooling to give a better answer to your needs/desires.
Have a dry run see how much depth you get from inside of lid to where becomes an issue with board and other parts like Ram etc plus don't forget to allow for fans which most likely 25mm plus 1mm for gasket.
So push something up to inside of lid like a thin piece of wood then mark it with a pencil then measure it.
Don't forget a 360 with be narrower than a 280mm as 360 is 120mm fans and 280 140's so the 280mm will be around 20mm wider
Also the more rad space you have ie bigger plus thicker higher FPI's.More efficient models the less critical fans/speeds/pump flow and routing of components.
where as less needs higher fans speeds/Better fans and more pump flow
OP
26 May 2019
Athens, Greece
Yes the problem with that case is that is "try and error". At the top is a piece of metal, in the bottom of it fits the raddiator, at the top of it the fans. 360radiator as far as i can see comes in 3.8cm height which covers a small part of the RAMS. Slim series is 1cm short (2.8cm). The radiator fits in that metal at the very edge of the case, so it does not come in contact with the motherboard in any way. So here comes the question: shall i go for thhe performance Kit or the Slim kit? For the time being i want to cool the CPU, and the GPU will be added in the near future.
My system is: CPU: Intel i7 9700K, Cooling: Noctua ΝΗ-D14 Mobo: MSI Z390 Tomahawk RAM: Corsair Vengeance 2x8GB, GPU: Asus Strix ROG RTX 2080, PSU: Thermaltake EvoBlue 2 850 Watts.
Οhh and nice to mmeet you guys!
22 Mar 2009
Hi myself i'd go with the P360 if it fits in ok?.Fans pref want on push so rads fixes to tray then fans screw onto rad for maximum air flow but if fouls have to compromise!
Yes looks like don't have a lot of headroom! and you'd probably need front rad for when add gpu!
22 Mar 2009
Hi just noticed your in Greece what are your room temps? as might need more cooling if "Hot"
You could also do off board cooling @pastymuncher and others have done your more or less unlimited then could have one or two rad+ and there is/was a 9 fan panel rad from Phobya or could have a 560mm rad 4x120mm
You could get a Aluminium box made for it to fit inside maybe even to sit on top of case or below with rad mounted on it's side so like a plinth?
If you wanted to get really into it you could add some Peltier effect units to rad where by you control cooling with volts/current they use in the outback to make power to run communications etc so pass power in one side gets hot other cold or place by a hot surface other side needs cooling and produces power!. https://en.wikipedia.org/wiki/Thermoelectric_effect
No this is bad your giving me Naughty idea's!!! mmm so where is that Dremel?
You could even install a loop via a fridge just bore two holes in side pass extension tube fittings through then seal round them then attach hoses to either side and rads inside with fans nice and quiet.
OP
26 May 2019
Athens, Greece
Hello aain mate. It depends on the season, but in any case 22-23 is the top temperature on my room.
22 Mar 2009
You can't use a fridge. It is designed for keeping cold things cold and cannot cool an active heat source.
So how did it cool the things put in it then?
But i'd better tell bod that's using one he can't! Should i go Smack his hands?:eek:
Hi ok not to drastic then ive got 24c here atmo!
18 Oct 2002
Aranyaprathet, Thailand
You know, you could try thinking about this. If you put food in a fridge, does it keep creating heat inside or does it simply cool down and stay cold? You're pumping constantly re-heated water into your fridge which now needs to ramp up its cooling. This is not something it is designed for!
But hey, not my fridge. Just trying to help.
What are the differences in cooling between a 360 raddiator and a 280 one?
assuming they are the same thickness, 280x14=39400 square mm area. 360x120=43200 square mm area. So a 360 is maybe 10% "better".
However, the 360mm uses 120mm fans so 3x120mm fans might get 3x75cfm=225 cfm, 2x140 might get 2x90=180 cfm. So that's 25% more airflow.
A single 280mm radiator might have less restriction than a 360mm (although flowrate isn't overly important so long as the flow isn't basically stalled).
Again, this is really hard to be precise. It all depends on way too many factors.
OP
26 May 2019
Athens, Greece
I see... So i go for the 360 kit....
5 Mar 2017
Cambridge
The advantages of AIO would be more not blocking the RAM with a massive cooler (considering your case allows the installation of the radiator at an ideal location), and easier to install. That's all.
Custom loops allows upgrades, as cooling other components.
Regarding prices, the idea of the kit is that would offer better value than individual parts, as packaging would be reduced, and the manufacturer manages to "push" few bits at their price, without being noticed, as tubing and connectors.
Worthy checking at https://www.caseking.de/, if prices may work better for you.
