Roku4K can't play YouTube Music
18 Apr 2003
England
Roku Streaming Stick+ keeps buffering YouTube Music when there's just a thumbnail, but YouTube Music with video is fine & 4K HDR is flawless.
Video below is me testing with an older RokuHD under the same conditions. To be clear however, the Roku4K struggles under all conditions eg. different router, TV, time of day or even just the Roku4K on the network.
I mention the YouTube app damaging OLED TV's but that's on another thread. I now use a second screen to play a video then get no damaging logo.
I'm now in the crazy situation of using the RokuHD on the 4K TV as Roku is only used for music now, so don't have to have the TV on & it be damaged by the app. By using a HDMI audio splitter to amp.
The Roku4K is now next to the router on a HD TV in another room & still can't play YouTube Music.
1 Mar 2010
like I said in original thread
works fine for me on an SS+ with 5G tv's about 50cm from a vriginmedia superhub .. two steps from hell victoy instrumental 5:22 - whatever that is
edit : incidentally who ever did the video knows little about speed tests ... you need to checks out comms with the utube cloud server
try your roku 4k at a friends house ? Do you have any links for people with similar problems ? - I had not found any, after the original post
OP
18 Apr 2003
England
Yeah good idea, maybe there's something on my network the 4k stick does not like, even in another room on a different TV / router.
Using the HD stick in the same place now & its fine & even has no issues with pilfering the audio from the HDMI feed as the 4k stick gave a HDCP error with some videos from YouTube.
OP
18 Apr 2003
England
Tried the Streaming Stick+ at a mates house last night & while 4K plays flawlessly, YouTube Music (thumbnail only) still buffers & stutters.
I presume there's a hardware or software fault with the Roku stick then.
Does anyone else have a Streaming Stick+ with YouTube Premium who could test a thumbnail only song?
1 Mar 2010
Does roku playback fail on any sound quality setting ? I found one small thread on roku community about this.
Do you really pay for youtube premium?
they have a high quality 256Kb/s option now, £10p/m is the market going rate, other than introductory offers is ... is their catalogue known to be 'limited' .. so why not ?
OP
18 Apr 2003
England
I'm a bit confused. I have audio quality set to very high on mobile devices with no issues. The RokuHD plays music with thumbnails ok too.
1 Mar 2010
Even though YM normal or HQ, works on other devices - is it not working on SS+ exclusively in HQ ? which could indicate bandwidth is somehow implicated in problem.
OP
18 Apr 2003
England
Maybe post over on the Roku forums, more likely to get someone else who has/is experiencing the same issue.
Just found a few posts about this on the Roku forums but none have an answer.
Its not possible change the audio quality on the Roku app but 4K plays fine which I presume requires more data.
1 Mar 2010
if they only provide the default 128kb/s YM on roku ss+ & rokuhd, that would be short changing you too.
have you tried setting the roku ss+ to pcm sound ... eg it's not sending a bitstream to your tv's .. and they are causing the problem.
OP
18 Apr 2003
England
I use a 2nd screen & pilfer the audio stream from the HDMI feed for an amp rather than the app damaging the OLED TV.
The issue occurs even if just using the TV or from a mates house on his TV.
Its fortunate I have an older RokuHD to compare & basically rule everything out. The Roku forums have a few posts about YouTube Music buffering but no fix.
OP
18 Apr 2003
England
Emailed Roku a video showing the fault on 25th May then 6th June the device received a firmware update & now YouTube (thumbnail) Music plays fine :D
Maybe the fault was fixed in the firmware update anyway but I'm happy.
