Hello all, got some money to burn and currently suffering the beginnings of the upgrade itch. However, I'm not having any issues with the performance of my hardware and as such not in a rush to upgrade them. Instead, I'm having issues with the case starting to look a bit worse for wear and a vibration noise from the Rad/Fan CPU combo.
Testing has identified the vibration noise to be coming from the rad/fan combo for the CPU cooler as when pressures applied the noise stops. My current thinking is that some sort of rubber mounting would help dampen the vibration that's being passed on to the case.
My current rig is as follows, sitting in a Corsair Air 540 case:
If I were to stay on air cooling, which case would you recommend and do you know of any kits that can be used to rubber mount my cooler?
If going for a custom loop, with a budget of ~£1,250 to get a new case and accompanying watercooling kit, what would you get?
- Intel i7 4790K
- Corsair Hydro H115i
- Gigabyte GTX 1080Ti "Xtreme Edition"
