PC won’t power on but mobo has power
5 Jun 2007
extremes.spacious.indelible
Hey all,
Strange problem, came home today and my pc won’t power on, no fan movement nothing.
First thought was a lightning strike as it’s been rainy today but everything else is fine and the PSU isnt blown as the mobo is receiving power as the power switch on the LED is lit by a red LED and the Ethernet port on the back in flashing.
Tried resetting the cmos via the switch on the motherboard and removing the battery for a few mins but hasn’t worked.
Tried one stick of ram and hasn’t worked.
Tried with all usb devices (including internal headers for RGB control etc) disconnected and nada.
I don’t have easy access to a PSU or other parts which I could test with so does anyone have any advice on what to try next?
Update:
The RGBs on the RAM seem to be lighting up now but still not sign of anything else?
Specs:
Ryzen 2700X
Gigabyte gaming 5 X370
Teamgroup Night Hawk RGB 16gb
Vega 64 Sapphire Nitro Plus
BeQuiet! Straight power 850w
The psu supplies a number of voltages 5v 12v -5 and grounds, so the higher volts might not be working but enough to light the leds.
I'm sure someone will be along who could help more.
Would a faulty PSU not mean that there wouldn’t be any power to the motherboard at all?
Unless completely dead, PSU connected to power always provides 5V standby to PC.
And even that LED on motherboard doesn't really tell anything sure...
Except that 5Vsb is high enough to get that LED glowing, but not high enough to burn it.
That's what I tried to say
Popped round a friends and nicked his PC and with the 24 pin and 8 pin from his PSU plugged into mine the PC now boots but doesn’t seem to produce a video signal (using HDMI on motherboard) and gives me an error code of 0d.
Don’t know anyone else with a Ryzen system so not sure how to go about testing cpu/mobo/ram :(
Ryzen doesn't have integrated GPU.
So you need to power graphics card and have monitor connected to it.
Motherboard's manual again doesn't list that particular debug code, so can't say what it means.
Ah that’s probably why I’m not getting any video signal then :(
Will need to wait till the weekend before I can get my mates PSU fully out of his machine then I’d expect :(
It does sound like the psu. It boots with your mates psu, so I would Rma it
Webnote sent, cheers for you help mate :)
Anyone know how long the BeQuiet! RMA process takes? Made a thread in the the wanted forum looking for a temp PSU just in case it’s going to be weeks.
Think this is my PCs way for thinking about selling her this afternoon :D
PSU is a good bet. But I would test your GPU in your friend's PC before sending off the PSU. Some systems will not power on with a dead GPU. And your testing with his PSU to only the 24 pin and 8 pin wouldn't rule it out.
Will give this a test.
On the topic of temp PSUs, would a EVGA BQ 650W 80 Plus do the job for a few weeks if it takes that long?
