Can you stop Windows polling the serial ports on boot up?
Permabanned
28 Nov 2003
Shropshire
I have some devices (solid state relays controlling large mains power supplies) running off the true serial ports on my motherboard. I use this set up to remotely switch the supplies on or off via remote desktop using a simple DOS program. However, on boot up Windows 7 64 bit seems to "poll" the ports sending outputs momentarily high a few times. The SSD's, the big linear power supplies and I don't like this! Can it be stopped? Thanks.
Man of Honour
13 Oct 2006
From my limited knowledge I think you are going to need a more advanced solution - either some kind of blip logic/power on detection circuitry or swapping to something like an Arduino Nano to control the relays.
Or move the system to another low power always on device.
Permabanned
OP
28 Nov 2003
Shropshire
I can't try the aforementioned method until tonight, I'll report back, hopefully it will work, the info certainly suggests it can do the trick, time will tell, thanks.
Permabanned
OP
28 Nov 2003
Shropshire
Unfortunately this has not worked. Someone elsewhere said it may be hard coded in the BIOS, but the sigs to the Serial Port do not occur until after the Starting Windows logo and just as the password prompt screen shows. it goes through two phases of polling the serial port about 5 seconds apart. I did the bcdedit /enum and after several reboots the off setting had stuck every time. I have also turned off the serial mouse in the registry with no effect. Thanks for the suggestion, any other ideas for me to try please?
13 Jun 2013
Brighton(ish)
Back in the day I used to have a old UPS connected to my workstation via serial port, when Windows booted it used to trigger the UPS to shut down, this was due to Windows polling for a serial mouse when it boots.
Have a look for this registry key:
Location: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\sermouse
Key: Start
Set the Value to 4
Permabanned
OP
28 Nov 2003
Shropshire
So does your receiving device simply change states based on a high signal coming into it from the serial port, or is it specific commands send down the line?
I would agree with the comments that your system reads as though it needs a bit more resilience to random inputs.
Yes, the DOS app just allows manual on or off, simple commands as far as my (very limited) knowledge allows. the ONLY issue I ever see is upon boot up, after the Windows log on screen.
Commissario
16 Oct 2002
In the radio shack
I don't know if it's Windows or the hardware doing this. I remember having a serial interface that would always blip the transmitter as the PC booted back when I used to run Windows. In fact, if I reboot my iMac with the radio switched on, it momentarily goes into transmit for a fraction of a second now and that's a 590 connected via USB.
22 Jun 2018
Doon the watah ... Scotland
Are you able to see what characters are being sent down the serial line ? With what you've disabled, it reads as through there is another service which is polling the com ports during start up.
Is the machine an old one thats had a lot of various programs and things installed / uninstalled over the years that might have left a service which has used the com ports and is still being loaded on startup ?
Does it do it if you boot into safe mode ?
Permabanned
OP
28 Nov 2003
Shropshire
I haven't tried booting in to Safe Mode, but I will. To be frank I saw my backside with it and made a little 5V linaer power supply in an alloy and now use an RF switched 13 amp plug socket adaptor to power the 5V supply and in turn that switches the big solid state relay. i can't operate it away from home, but at least it doens'y have a mind of its own ;) i will try Safe Mode though, but further reading shows many others have this (including Mr Feek), and it was impossible to tame. Thanks for the replies everyone!
Man of Honour
13 Oct 2006
Definitely worth looking into something with a microprocessor like the Arduino (the Nano has a fairly simple interface and lots of output options) or RPi for this kind of thing.
Permabanned
OP
28 Nov 2003
Shropshire
I am probably too old to bother getting in to programming stuff, but I certainly agree they are extremely useful gizmos! Thanks.
