- 22 Feb 2014
I have bought an MSI B450M PRO-VDH V2
Set my multiplier in the bios and currently running PRIME95 to test stability, but the BUS Speed is jumping around anywhere from 95mhz to 99ish Mhz, meaning that the overall clock speed is varying by up to 200Mhz.
Spread spectrum is disabled, anything else I should be looking at ?
with the stock cooler temps were up around 59oC
with an old Corsair 120mm AIO I had lying around temps are currently sitting at around 45oC
