My parents live in the states and they had a lightning strike near them which fried many electronics in the house.
Ive tried to diagnosis the computer problem via whats app but not sure ... Its my parents and they are 70ish so you can imagine trying to get them to tear open the computer etc ...
This is what I know:
- Its a fairly old pc that I built - not quite sure the MB its a varient of the DFI lanparty p35, has a ati 6950 gpu and a antec powersupply.
- The case fans come on when the power comes on, the cpu fan, the psu fan comes on the gpu fan.
- Nothing shows on the monitor and they bought a new one because their cable guy said it could be the monitor. Meaning there isnt a signal coming from the computer to the monitor.
- There are 2 lights on the MB both appear normal; a dram power led and a standby power led
https://www.manualslib.com/manual/451662/Dfi-Lanparty-Dk-P35-Series.html?page=15#manual
This is just a general manual for the MB again not sure the exact one.
- I have 2 drives connected to the computer one SSD and a storage hhd.
Again nothing shows on the screen when powered but the fans spin up and the lights go on. I dont think the montior has any error code indicators or beeps.
I had my step dad take out the GPU to see if he can get it tested somewhere if its more complicated then that ie the cpu, ram or mb got fried they are probably better off buying a different one.
any suggestions?
thanks
any suggestions?
thanks
