Backing up photos from iphone to PC
7 May 2012
Bournemouth
Apologies if this has been covered, but my mum has an iphone and has just spaffed 39 EUR up the wall buying some scam "photostick" USB device from some dodgy site that looks like it was designed in the late 90s to scam people who don't know any better, all because she can't back her photos up on her (windows) laptop.
I have never owned nor intend to own an iphone, but have been told that backing photos up can only be done via iTunes? Is there any way around this typically slimy Apple practice?
ajf
ajf
30 Oct 2006
Worcestershire, UK
If you plug an iPhone in via USB you have read access to the DCIM folder and all of your photos.
+1 for this. Easiest solution for now.
Long term, as mentioned any of the main cloud services have camera roll backup.
Personally use iCloud for 79p per month for 50Gb, but OneDrive works well too.
Not a huge fan of the Windows iCloud client though, always seems to play up for me.
OP
7 May 2012
Bournemouth
I've been told that there is no option to explore files in any way when connecting iphone to PC? Apparently it just brings a pop-up talking about itunes?
Man of Honour
29 Jun 2003
Wiltshire
It randomly stops working for me (kept saying I wasn't connected to the Internet, seems to be a common problem), so had to uninstall it and cancelled the extra storage and went with Google Drive/Photos in the end. Not ideal as none of the third party apps like that sync automatically without opening the app but got fed up with iCloud not working.
Wzd
Wzd
26 Feb 2004
London
When I plug my phone in and then look in Explorer I see this...
As long as the phone is unlocked you can browse to the phone's DCIM folder.
Also on my PC if I do this there is an option if you right click on the iPhone device to "import pictures and videos". Then there is a "more options" link to choose where on your PC to import them too.
OP
7 May 2012
Bournemouth
Thanks, will pass this info on!
Still can't get over how scammy this whole photostick company is. Take a look at their website. It's a masterpiece on what to avoid!
18 Feb 2007
London
Does iCloud back up photos as well then, I have the standard iCloud plan which costs nothing, might need to upgrade soon if i use up the 5gb.
Is it a good idea to copy your photos folder to a usb drive very so often as an extra backup, does anyone do this or just rely on iCloud to keep photos safe?
18 Oct 2002
Cheshire
I use OneDrive, which is synced to my PC as well as turning on iCloud Photo Library. So effectively that gives me a local copy on the phone, a backup in iCloud, a backup in OneDrive and a local copy in OneDrive.
