- 6 Sep 2016
Any recommendations for panels that I can put on the wall to reduce bouncing and echoey sound? For home cinema and hifi rooms
There is nothing else in the room except a chair, just carpeted floor
Did you not read any of the above. You got to be trolling. Learn how your 2 channel/multi room setup interacts with your room. Learn where the first point of reflection and second are in your room. Effective acoustic treatment is based on knowing the sound acoustic attributes of your room and effectively using a combination of diffusers and asorbers where needed also the density of the material used for the treatment plays a major part.
Duvet on the wall= Audio Chav.
Go to uni do PhD in audio befor knowing what to do, are YOU trolling?
Not really about duvet try it out, no expense see if reduces clapping echo if it does then those sound panels be ok
Not going to pay for audio investigator what I'll try is putting thick duvet on the wall see if that helps the echoes and then look for cheap panels.
That's an incredibly stupid and ignorant thing to write... Snip.
