Help spec me a 4k monitor
15 Sep 2009
Birmingham
I'm after a new monitor but after HD gaming for a while and with the addition of an RTX card I'd like to go with 4k
I have been interested in either
PREDATOR 4K XB281HK 28" 3840X2160 TN G-SYNC
LG 27UK600
AOC U2879VF
Benq EL2870U
What are peoples recommendations or opinions?
Look no further than the Acer Nitro 4k. Yes, it busts your budget but it's worth it. Never stint on protecting your eyes.
Apparently Acer have done a bait and switch with the Nitro, as I see reports of terrible backlight bleed "starting from February", whereas of course TFTCentral and other reviewers' samples weren't nearly as bad.
At 4K as long as you have Nvidia gfx then GSync is way more important than a gimped version of HDR. I have the 28” TN Acer 4K monitor and I have no complaints with it and with gsync my old 980ti could keep the frame rate up even at higher settings.
It’s a shame OCUk don’t price match! Would much rather buy from here
the main difference I can see is gsync on the acer and hdr on the LG
they will if you phone customer services nd ask nicely :)
well, most of the time.....
i to am after 2 x 27" 4K's as decided to sell my 32" 1440p and keep my 2080TI.
Very good service indeed - bought the monitor from OCUk as my preferred supplier for IT bits and they credited me back some of the difference
I went for the XB281HK in the end and cant say anything negative about it. Monitor is amazing in 4k with gsync on a 2070
excellent, glad they saved you some. i measured up last night and i will go for 1 x 28" 4K now instead of 2. how much did you get the XB for in the end?
I'd look at the XB321HK if you can stretch to it. 32" is a far better size for 4K, and the XB321HK is still the ONLY 4K monitor at this size with G-Sync, bizarrely. I have one myself and aside from the 60Hz limitation, I cannot complain.
32" now for sure. i will see if my budget can stretch but i'd prefer it not to. i'm not after the best of the best, just a good one.
