- 28 Jan 2005
- Lymington
Hi All,
I recently upgraded my monitor to a ASUS MX34VQ (3440x1440 100Hz Freesync). I am loving the higher resolution and immersive feeling of the 34" curved screen. However, gaming performance has really taken a nose dive. Prior to this I was running 2560x1080 @ 60Hz. I generally play Division 2, Wildlands and will be getting Breakpoint. The issue is low frame rates and a generally choppy experience. Wildlands in particular, even on medium struggles and will drop into 37-40fps at times. Division 2 runs better but still gets annoying stutters. My system specs are as follows:
AMD 2700X @ 4.1GHz cooled by H115i Pro
Gigabyte B450 AORUS M
16GB DDR 3600 @ 3000MHz CAS16
Vega 56 Pulse @ 1600MHz core, 900MHz HBM and a slight undervolt. Holds these clocks during gaming.
1TB Corsair MP510
850W Corsair PSU
Fractal R5
I also have another gaming PC that is very similar but has 4.25GHz on the 2700X, an Inno3d 1080Ti X3 and a Acer Predator XB271HU (2560x1440 165Hz). Gameplay on this is much smoother, it's night and day. I've actually plugged in the Asus Freesync monitor into this PC and the FPS increases to about 65fps on very high in Wildlands so I definitely know it's a GPU bottleneck. Gameplay was smooth and even though Freesync was not enabled it was a much more enjoyable experience. I am left wondering what to do now. I've a few options:
1) "Upgrade" to a V64, clock the nuts off of it and see if that extra bit of grunt helps. This would quite cheap but unsure if I would notice much difference.
2) Upgrade to a 5700XT.
3) Upgrade to a 1080Ti for about £430, enjoy raw performance but miss out on Freesync.
4) Open my wallet really wide and get a Vega VII.
I don't want to keep turning down graphical settings so am happy to spend out. I ran a quick Timespy run and got 7065 which I think is about right so the system is performing as expected.
1TB Corsair MP510
850W Corsair PSU
Fractal R5
The state of the market is just quite poor so once you get to this kinda resolution there isn't really a great buy.
