Stock timespy score on RTX2070
Caporegime
18 Oct 2002
Lake District
The time spy benchmark thread only has overclocked 2070's, what should a stock i7 9700 and a RTX2070 score?
MSI RTX2070 Gaming Z (stock)
Auto OC scanner custom curve, +500 memory.
Tried with power limit 112%, it sat at over 1800mhz for the entire run.
Still 7725
MSI Armor 2070 8G if that matters.
There is definitely something up with your system as your Cpu score is way down on what it should be. Losing around 800 points to Guru's result there. Could try setting windows to high performance mode. I take it all chipset drivers are up to date. Maybe updating to the latest bios for your motherboard if it's not already on it. A fresh install of windows if it's fairly old.
https://www.guru3d.com/articles_pages/intel_core_i7_9700k_processor_review,17.html
Yeah as expected your GPU boost clock is far too low.
Your core clock should be hovering anywhere around the 1960-2025 mark.
What are your GPU temps under load?
*Try temporarily whacking your case and GPU fans to max when running the benchmark.
@TheRealDeal - My CPU score is far lower than his, so that is not the limiting factor here.
Doubt it, it's a non A chip like mine, it settles down to ~1865 boost@stock-temp limited.
Mines hit a max oc of 2025 on a flashed bios with higher power limits, before that it wouldn't hit 2GHz due to lack of power-exactly as intended by Nv unless you paid more for their A chip.
A pure **** move by Nv imo but £100+ wasn't worth +300Mhz.
Your Cpu is not a 9700k though. There maybe a link to why both his cpu/gpu scores are lower than expected. I don't think his cpu is holding the graphics back but pointing out his 9700k is also under performing.
Ah yes I think you are correct.
Guess I lucked out picking my Gaming Z up for £380.
The current price for it is totally ridiculous though.
:eek:Well done mate!
Here was me thinking I got lucky paying launch day mrrp of £439 for my WF(elsewhere-because Gibbo refused point blank to sell it@mrrp because imagine he needed his gouging cut from the £60 to finance his Ferrari:p).
That’s a mental clock for that bottom 2700X. I thought I was doing alright getting 4.5Ghz!
I didn't do the oc, I don't have a clue or the inclination(too lazy now:p) on how to clock AMD via bios, it was Aurus engine on my X370-Gaming K7 that auto clocked it.
Coming from just raising the multiplier on Intel as I said cba working out how to do it on AMD, besides both cpu/gpu run at stock 99% of the time anyway.:)
Just realised reading that back that I'm now classing paying non gouged mrrp as 'lucky' what an utter disgrace the PC scene is these days due to the sheer greed from the manufacturers all the way down to the etailers!
Roll on PS5/XB*, even if they cost ~£6/700 they will destroy and embarrass a ~£6/700 PC!!!
