Current PC clean etc?.
10 Feb 2011
Hi as some of you no and along with a lot of others I am thinking about buying a new AMD CPU and Graphic card bundle from OC UK. I currently bought this PC I have now near 3 years ago here. Ive messed about with it loads since and formatted it and even reset bios etc. Ive damaged a couple of USB ports on the top of the case too but still work.
The PC was called Titan Virtual Force VR Gaming PC - Intel Core i5 6600K @ 4.5GHz, Nvidia GeForce GTX 1070 8GB Graphic.
I changed to an I7 6700k and put in a 1080GTX.
Kingston Fury Black 16GB (2x8GB) DDR4
KFA2 GeForce GTX 1080 EX OC 8192MB GDDR5
Samsung PM951 256GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive
Seagate 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD
Z170e motherboard
Phanteks Eclipse P400 Midi Tower Case - Gun Metal Window
I dont no what the PSU is its not listed in my account for some reason.
Would it be a good idea instead of buying a new PC is to send this to OCUK have it cleaned, new case and other upgrades if needed?. Have OCUK have a look at the bios set it back to default settings and have them Overclock it and test it like it was new?.
CPU has even been cleaned and new paste been put on recently too as it was over heating but this sorted it. I took it to a local store in my area and well known. Only cost me £30 and it was kind of cleaned then.
Not got any local mates that know enough to do this? Seems a waste to send off to OC. Specs look solid.
They may be able to send you the bios profile for the OC.
I never thought of asking them for profile and after reading you comment I have just opened up a web not asking if they have it for this board. I put my order number in too so they no exactly what I have.
If you've only cleared the CMOS and not updated the BIOS you should have a 'clocked profile' saved within the BIOS.
No I upgraded the bios and didn't think it would wipe the oc but it did and I didn't save the profile to usb. DOH. Any way I will wait and see ocuk come back with. Hopefully they will be kind enough and give it to me for free.
Well ocuk came back quick and said they dont normally give out profiles but has tried helping me overclock it. This what they gave me.
Enter BIOS, Go Advance mode
A.I Tweaker
AI Overclock Tuner - XMP or Manual (Use XMP if available)
(If XMP not available) DRAM Frequency - 2400Mhz
CPU Core Ratio - Sync all Cores
1 - Core Ratio - 45
Digi + VRM
CPU Loadline Calibration - Level 7
CPU Core/Cache Voltage - Manual
Core Voltage Override - 1.32v
DRAM Voltage - 1.40v
CPU System Agent Voltage - 1.20v
