AMD Update took away my option to turn on Zero Rpm mode !
5 Aug 2006
Northern Ireland
hi
i have a custom curve which is great with no problems but had some issues with a game so did an update and no i cant turn on RPM mode at all, please can someone tell me if there is a fix for this?
many thanks for any help
hi
What thing you "updated"? Drivers? Settings?
I'm sure someone will correct me, but I believe the zero rpm button never actually worked on custom profiles.
updated drivers and yeah i have always had the option to turn on/off the Zero rpm with the custom curve ive always had but latest driver update took it away and its just on with no way to turn it off
Had the same issue, you can fix it by changing an option in your .xml file for your wattman profile. Have to change something like the 3rd option from the bottom to "false"
I'll check exactly how I did it when I'm home from work later.
Zero rpm works on my wife's Sapphire Pulse Vega 56 with a custom profile. The zero fan button is ticked but I can't remember if she is on the absolute latest drivers.
Interesting.. I've had the option to enable it in the past, but the button wouldn't actually do anything.
I never bothered looking into it, because i was messing with game profiles and i figured the fans would be on regardless.
