Lawn advice please!
13 Jan 2006
Wigan
Hi so this is my first time looking after grass.
New build in April with fresh rolled turf. Watered it for a solid 3 weeks every day until it started raining and let that take over. It has rooted in nicely but it is just really patchy.
Its been down nearly 3 months and looks like this right now:
This was a week ago after a mow the day before:
Basically what do i need to do to get it nice and green and nicely maintained?
I think i may need to reseed a few of the patchy areas?
Any help much appreciated!
11 May 2004
Curitiba
A few things.
Are you watering it enough? Do you know what grass type you have? If you can get close up shots that would help.
OP
13 Jan 2006
Wigan
A few things.
I haven't watered it since the initial 3 weeks of it being laid. It has rained on and off.
What’s the soil like ?
Drainage ?
No drainage issues, i have no idea what the soil underneath is, nothing was put down before the grass was rolled out though. There are a few bits of brick and rock dotted about. Thry did a bit of a crap job who ever put the grass In.
Feed it.
Mow it regularly (little & often).
Don't mow during extreme heat or drought.
I have been mowing once a week for the last month. I will try raising my cutting blade a bit this weekend.
I did a weed and feed last week also
17 Mar 2009
The Shires
New build gardens and turf are always a struggle. Little tip soil before the lawn was laid and drainage will be poor.
As said above little and often, never take more than a third off and use a fertiliser. I use a mulching lawn mower as well which chops the cuttings into little pieces and leaves them on the grass so at least some of the nutrients will go back in. And you don’t have to do tip runs with grass cuttings
11 May 2004
Curitiba
I would suspect it is suffering from heat stress if you haven't been supplementing with water or scorching from the feed and weed. I tend to avoid feeding in the summer unless you have warm season grass and have good irrigation. If you want to add a feed in the summer for your cool season grass, I would either opt for an organic based one or if going the synthetic route then one with a relatively low nitrogen content.
Mowing higher as mentioned would also be beneficial especially in the summer. Longer grass blades will hold more moisture and be better in photosynthesis. Not only that but it will also provide better shade for the soil reducing the need to water as much and cut down on weed infestation by crowding it out.
17 Nov 2003
St Breward Cornwall
bottom of my garden can get a little like that from time to time ,i also use the mulching attachment on my lawn mower and also set it to level 3 ,not too short so it retains moisture, never used a fertilizer tbh
7 Sep 2008
when you mention mulching lawn mower
what does it mean>?
I got this yellow plastic thing I never use it. it supposedly fits inside the bag - is that a mulcher?
16 Apr 2012
A mulching mower means you dont need to have the grass collector on. Inside the mower they should be a plug to stop the grass going to the collection box instead it gets cut into fine pieces and is deposited back onto the grass helping to feed at the same time.
14 Nov 2002
Under the Hill
Dig it all up, take out the layer of crap the builders left behind, get in nice new suitable subsoil and sow a decent seed.
I wouldn't bother, as long as it's draining ok it should be fine.
I would hollow tine and brush sand in it each year, give it feed, let it grow and only take off about a third of the length for each cut.
