Check my build please
12 Jun 2019
Hi guys, just wanting a build check please.
The AIO I've picked is for the roof but not really sure what I'm looking for when picking one, would this one do the job?
Also, are all the components I've picked compatible? Been observing the forums for a month or so and I think I've managed to learn a few things but would be nice to get some opinions.
Thank you.
My basket at Overclockers UK:
Total: £1,530.04 (includes shipping: £13.20)​
@Chaze
just dont forget to register 4 year warranty with the gigabyte card !!!
avoid kolink case! cant control fan speed!!!!
corsair site has 3600hz non rgb ram for under £100 in stock along with SSD !
board is solid but make sure you update to latest bios ! sorts out low boosting speed for single/dual cores !
better cases
https://www.overclockers.co.uk/cool...ower-case-black-tempered-glass-ca-37k-cm.html
https://www.overclockers.co.uk/cool...ower-case-black-tempered-glass-ca-379-cm.html
link in with cooler master aio
https://www.overclockers.co.uk/amd-...essable-cpu-cooler-bundle-bu-014-cm.html#t=a4
rgb ram to control with the board software
https://www.overclockers.co.uk/king...00c16-3200mhz-dual-channel-kit-my-28u-ks.html
should be able to push 3400hz without changing timings
Thanks @orbitalwalsh
Those two cases were also ones I looked at so will pick one of them.
The non-RGB rear fan will annoy me though. If I replace it, is there one that can be controlled with the front 3 that you could
recommend please?
Will defo go for that CPU cooler bundle and take a look on the other site for ram & SSD thanks.
recommend please?
argb
https://www.overclockers.co.uk/cool...120r-addressable-rgb-fan-120mm-fg-02l-cm.html
rgb
https://www.overclockers.co.uk/cooler-master-masterfan-mf121l-rgb-fan-120mm-fg-02h-cm.html
same model as case
cooler master can be plugged into the board and controlled via software from board vendors aswell
Just one final question. If I purchase the SSD from elsewhere, how easy are they to fit/install for a complete novice?
I know the memory is just push and click.
Installing storage before OS install is easy. Just plug it all in. If M.2 goes straight into slot on the board. If Sata needs a power cable and sata data cable (all provided with PSU and mobo ) and mounted in the case.
If add after OS install then you have to go into windows and format it .
Arrived yesterday, had a quick play with it last night and couldn't be happier :)
What kind of software/applications do people use to check RAM, CPU speeds etc?
Not sure I will change anything but would be good to see everything's as it should be.
Cheers.
Cheers.
nice to see it all up and running !
lot use ryzen master for CPU and ram .
Yeah that's what I ended up using in the end.
Only thing I had to change was XMP in bios to get the memory up to speed, happy with everything else so gonna leave well alone for now :)
get some snaps up ! @Plec loves a good flash of hardware
Hah - this is a pure @orbitalwalsh fixation/addiction. He's like a junkie trying to score his next fix and using other members as pawns to justify his request for image uploads.
That said - pics are always welcome - plus, it helps keep Orbi's demons at bay (well, a few). :D
Haha well I've just posted some pics.
Thanks for the help guys :)
Here you go @orbitalwalsh - remember to breathe:
*Looks good @Chaze.
