Is there any website or tool where you can find out these results? For example, I have a 6700k @ 4.6ghz, would be interesting to see what gfx cards would bottleneck my CPU.
If you monitor is only 60Hz, the bottleneck shouldn't be so significant as the max frame rate you are aiming for is 60fps anyway; but if you got a 120/144Hz monitor, your max frame rate rate aiming for is 120/144fps so it literally require twice the CPU grunt of pushing 60fps, so the CPU bottleneck would definitely happens (not in all games, but definitely would be in most of the modern demanding games), when the graphic card is not the bottleneck.So a 2700k @ 4.6Ghz with a 2060S @ 1080p will be fine then?
Gpucheck.com is good at comparing CPU’s and GPUs, it’s not far off the true fps either.Is there any website or tool where you can find out these results? For example, I have a 6700k @ 4.6ghz, would be interesting to see what gfx cards would bottleneck my CPU.
You're right with it bottlenecking, I've got a 1070 and that gets slightly bottlenecked depending on what game I play. If OP really wants to hold on (which isn't really worth it now 3600 is here) then a 3770k with a BIOS update would be his best bet, although it'd still be bottlenecked a considerable amount.The 2500K can absolutely not handle a 1080Ti, that's utter crap.
In fact the video you posted literally shows an OC'd 2500K being heavily bottlenecked versus a 2600K in single player games....putting aside that the 2600K itself would bottleneck a 1080Ti.
The video is also based on games from 2016, try playing the latest Assassins Creed or Battlfield online with a 2500K and it would literally bottleneck a GTX1060....forget about a 2070 Super.
My experience lines up pretty much exactly with yours. Even with a 2600K it wasn't great.You're right with it bottlenecking, I've got a 1070 and that gets slightly bottlenecked depending on what game I play. If OP really wants to hold on (which isn't really worth it now 3600 is here) then a 3770k with a BIOS update would be his best bet, although it'd still be bottlenecked a considerable amount.
The worst thing about being bottlenecked is the sudden hit from 100 fps to under 50 fps with those 0.1/1% lows.
My 3770k 4.5ghz is on par with a stock 6700k, not terrible but certainly lacking for heavy CPU games for 60 fps minimums, still we've had these for 7+ years so certainly can't complain!Looks like my 2700k is on par with a stock 4770k or ryzen 5 something
Thankfully the only things I'm looking at this year are BL3 and mechwarrior, I'll upgrade next year for cyberpunkMy 3770k 4.5ghz is on par with a stock 6700k, not terrible but certainly lacking for heavy CPU games for 60 fps minimums, still we've had these for 7+ years so certainly can't complain!
Yeah those will be fine, I still haven't played Witcher 3 while I wait for my CPU upgrade, 4 years later still waiting ^_^.Thankfully the only things I'm looking at this year are BL3 and mechwarrior, I'll upgrade next year for cyberpunk
Witchers 3 ran fine on my 2700k and old 980 at 1080pYeah those will be fine, I still haven't played Witcher 3 while I wait for my CPU upgrade, 4 years later still waiting ^_^.
