Lmao, got a ryzen too..... want my fingerprint included on the pic?
Exactly, I truly not believe you unfortunately
Exactly, I truly not believe you unfortunately![]()
Nice looking system that Gavin.
Sorry to hear that, but i understand.Thanks man. Unfortunately I'm plagued by driver issues so the card is going back.
I find it unusable at present.
Was your default clock speed in WattMan not 2063Mhz?Got mine plugged in. OC Tools not working properly though i whacked the powerlimit slider to max and ran with it.
My boost clock is 2050mhz, i did not set this clock manually.
timespy : https://www.3dmark.com/spy/7826108
firestrike extreme: https://www.3dmark.com/fs/19902061 - GS is 13,345
firestrike extreme 1080ti HOF EK Custom Watercool (stock, no PL or clock tweaks - 1979 boost clock) : https://www.3dmark.com/fs/19901682 - GS is 14,396
In these synthetics my 1080ti HOF WC is 7.88% faster in these benches. Just gonna load up Dirt 2.0 and OCAT.
Thanks, just wondering if all AE Editions are set to 2063Mhz at stock or if there is a little variation.I will check after tea.
No idea mate i am not responsible.@LtMatt why the Navi do not post the true speed, which is 14000Mhz / 7000Mhz (x2) as is GDDR6 ram, like Nvidia cards do, and they post 845?
Try restarting mate, should fix it. If not, DDU in safe mode and reinstall the driver. Make sure you are downloading and installing the full 19.7.2 package from our website. Heard of a few issues when using the Auto Detect, minimal driver version or updating via Radeon Settings.had a cheeky look on wattman and all the readouts are b0rked. All i have is a curve on the screen going all the way to 2100mhz/1186mv.
blimey, the new radeons setting and wattman panel makes the nvidia control panel look like it was written in 2008.
Breaking News : Hell frozen, @gavinh87 got AMD CPU & GPU
(OK i believe you now, mea culpa).
Btw it is me or the power supply cable you are using splits to 2?
The 5700XT only needs 8% beyond where I am and it basically matches the 2nd fastest 1080ti produced in a synthetic.
Power cable splits to 2
Btw I dont hate AMD, just their products. Now they finally something worth buying I'm interested.
