RTX 2070 Super, What Next?
17 Sep 2007
Liverpool
Hi All,
I've recently upgraded from 1060 6gb to the RTX 2070 super and although games are more playable i feel like something in my system is holding me back, thinking ram speed / processor. Any suggestions would be great.
i was thinking i could upgrade the ram to 3200mhz but not sure how much of an impact this would have on performance
19 Dec 2010
Hi All,
What resolution are you playing at? 1080p or 1440p?
14 Aug 2018
Unless you were playing at 1440p+ then I doubt a gpu upgrade would ever have impressed you much.
Indeed, though you really can't go a 'feeling'. Did you do benchmarks before and after in the games that you play? Your RAM speed does seem a bit slow at 2400Mhz for the 1000 series though I'm no expert.
18 Feb 2015
bit of everything really (F1 2019, Battlefield 5, Assassins Creed, The Witcher)
I only play at 1080p at the moment
Yup, definitely the CPU. Could use an R5 3600 instead. RAM also quite slow sadly, though it might be tricky to get fast ram in that mobo. At least in the meantime you might want to just up resolution/render scale, enjoy some extra eye candy. Would probably advise you to cap FPS to 60 as well (weird behaviour otherwise, sometimes).
OP
17 Sep 2007
Liverpool
Unfortunately not, but I can now play all of those games with everything maxed out at 1080p (struggled to get solid 60 with low-medium with 1060 6gb). With the 2070 I'm experiencing some weird issues in games but I'm putting that down to teething problems with new cards and drivers
the motherboard supports 3200mhz max :/ my computer was originally a budget build
Permabanned
28 Nov 2006
N Ireland
That is why you should make the next one around a strong case psu and cpu etc probably best you save for PCI 4.0 Ryzen with a 800w psu. Then you can swap the graphics without worry next time.
TLDR spend on everything but the gpu first time around imo.
OP
17 Sep 2007
Liverpool
This.
That card is really for higher resolutions anyway, so grab yourself a nice 1440p monitor. :)
I think that is probably the best option for me for now, I'm long overdue a new monitor and I haven't really got the money for a new processor, psu and ram.
Any idea on how much performance I could be losing sticking with 1600 for now? From what I have found online it's looking around 20-30% :( I know there's no such thing a future proofing with tech but hopefully i will get a good few years out of this card :)
20 Nov 2009
Haarby, DENMARK
A ryzen 5 3600 or ryzen 7 2700 would be a good companion along with 3200MHz ram.
Yet I am pretty sure you are even limiting/bottleknecking your Ryzen 5 1600 CPU right now with just 2400MHz ram. I am sure if you get 3200/3000MHz ram, your R5 1600 will really stretch it's legs.
HeX
HeX
20 Jun 2004
Huddersfield, UK
That memory will probably OC to 2800+ if you have a play. Will give a nice boost. Then you want to manually OC that 1600 as high as you can (~3.8-4.0 should be doable).
OP
17 Sep 2007
Liverpool
Thanks everyone for the advice, I've managed to oc to 3.9 stable and the ram to 2800 which has significantly improved frame rate. however in games BF5 the game stutters / freezes for about a second and the cpu usage shoots up from around 70% to 95% :( looks like i will have to upgrade to see the benefit of this card.
UserBenchmarks: Game 114%, Desk 95%, Work 93%
CPU: AMD Ryzen 5 1600 - 91.6%
GPU: Nvidia RTX 2070-Super - 136.9%
SSD: Samsung 850 Evo 250GB - 112.5%
HDD: Seagate Barracuda 2TB (2016) - 97.6%
RAM: Crucial BLS8G4D240FSA.16FBD 2x8GB - 102.5%
MBD: Asus TUF B350M-PLUS GAMING
https://www.userbenchmark.com/UserRun/18596879
