4k video editing PC build - thoughts?
24 Mar 2011
This is an all-rounder PC, a balance between CPU, GPU, memory and storage.
What is the performance bottleneck for 4k long GOP video editing?
Will 500GB be enough space for the OS, apps and your current projects?
You can get some good deals on a 1TB m.2 drive.
Seemed silly creating another thread, and I've stolen most of the above, but any improvements on the below?
My basket at Overclockers UK:
Total: £1,484.52 (includes shipping: £19.62)
Already have a 1TB SSD for the OS (and monitors, peripherals etc), and the 2x 6TBs are going to be in RAID1.
All our machines are Intel-based atm, one similar having an i7-7800 3.5Ghz and GTX 1080Ti 11264MB. I'd rather stick with Intel just so there's some swapping ability if needed but are the Ryzen's THAT much better for video/animation?
(Additional case for another use!)
That motherboard is pretty much garbage.
VRM is very flimsy design and runs easily hot and then it doesn't even have any heatsink!
This would be better and with actual heatsink for cheaper:
https://www.overclockers.co.uk/asrock-b450m-pro4-socket-am4-ddr4-matx-motherboard-mb-16c-ak.html
And compared to Asus this is high end.
https://www.overclockers.co.uk/msi-b450m-gaming-plus-socket-am4-ddr4-matx-motherboard-mb-349-ms.html
Also for Zen2 Ryzens you need to have BIOS updated to get PC to boot/POST.
Geomapping is PCIe 4.0 main selling point . thousands of 32mp plus images being pulled from storage and stage 1 and 2 being passed to and from storage is only program i can recommend pcie 4.0 SSD.
pcie 3.0 could shave off half a day to a full well in workloads but not the same for video editing .... yet ...
if your going B450 then MSI with is flash option- needing beefy VRM for 8 cores then B450 ITX Aorus or MSI boards.
gigabyte only vendor that can have board sent to and flashed for you
After doing a bit more reading, this may be a bit more money but more appropriate? Faster SSD and motherboard is more appropriate, no RAM speed overlcock required and compatible with the processor from the off.
Anyone got any experience with the case?
Total: £1,066.07 (includes shipping: £13.20)​
Order placed, went with the following in the end:
£37.49 x 1 - Kolink Stronghold Midi Tower Gaming Case - Black Tempered Glass Side Window
£182.49 x 1 - AMD Ryzen 5 3600X Six Core 4.4GHz (Socket AM4) Processor - Retail
£74.99 x 2 - Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black (CMK16GX4M2B32
£207.49 x 1 - MSI GeForce GTX 1660 Gaming X 6144MB GDDR5 PCI-Express Graphics Card
£54.16 x 2 - Toshiba 3TB P300 7200RPM Performance Hard Drive (HDWD130UZSVA)
£149.99 x 1 - Asrock X570 Phantom Gaming 4 (AMD AM4) DDR4 X570 Chipset ATX Motherboard
£104.16 x 1 - Corsair RMx Series RMx750 750W '80 Plus Gold' Modular Power Supply (CP-9020179-UK)
£14.99 x 1 - Arctic Freezer 7 Pro Rev 2 CPU Cooler
£4.96 x 4 - Arctic Cooling P12 PWM PST Black Fan - 120mm
Very similar to yours cooper. Like I said already have a 1TB SSD and peripherals.
