Best fans for black ice gts rads
Vardars are solid. I also am a fan of silent wing 3 fans though they trade temps for noise.
If it’s apart of your temp cpu question, I would get a temp sensor in place first. Given you mentioned your GPU is 40 degrees under load, your water would be at least a few degrees colder, so mid 30s. Add in the fact that ambient temps you mentioned right now temps are high 20s, your water delta temperature is actually reasonable.
Thanks for the response mate, yeah I don’t think I have ever seen my gpu higher than 44c an that was after about 4 hours gaming
I'd thoroughly recommend picking up a GT1850 and giving it a try. I havent tried any of the Vardar series but the GT1850 when paired with a GTS/X rad is as good as things get :) Amazing combination.
