Attaching Sky dish to freeview tuners on TV
26 Apr 2012
My Sky TV package is coming to an end soon and rather than renewing I am thinking of cancelling and using the twin tuners built into the TV (kd-55xe9305) I was told that Sky use different "special LNBs"? and its not as simple as just plugging it in into the TV, has anyone done this recently?
Cheers
It will work fine however, because the TV doesn't have freesat you'll be stuck with the Sony guide, which is absolutely diabolical and practically unusable
Haha, ok so I maybe better off getting a separate freeview box. Thank you
No worries, semantics, but will need to be a freesat box if you want to use the satellite connections. Have you not got a normal aerial you can use? then you can use the built in freeview and youview.
I do have a TV aerial yes, so I was just looking at the TV spec (LINK) and it says
Number of Tuners (Terrestral/Cable)
2(Digital)/1 Analog
and
Number of Tuners (Sat)
2
Do you know if I plug the normal aerial into the TV if I would be able to watch one program and record another via USB?
I don't believe you would no. It's counting the two satellite tuners as digital and the aerial/coax input as analog despite it being a digital tuner.
So in theory you can only record the program you're watching or have it record something when the tv is "off".
The newer Sky dishes must be different because older boxes don't work on the newer ones. I tried an old box at my step sons house they've just moved into while they waited on new Sky installation.
Its not the dish but the lnb.
You can ask the engineer when he installs sky q to install a hybrid lnb and that will work fine.
