I'm sat with a non-OC'd 6600k with an RTX 2070 Super on the way, I play at 1440p so surely just an OC on the CPU would be enough to cover the 2070 at that res?
I switched from i7 [email protected] to R7 [email protected] hoping that I will be able to run a lot of programs in the background while gaming without performance hit and I have to say that I'm disappointed. Not only my average frame rate dropped (which was expected) but also I'm getting a lot of frame drops where my GPU usage drops to 70-80% and that's at 3440x1440 using 980ti..! No idea what is going on.
I didn't reinstall win 10 after the switch but why should I.?
Tomorrow I'm getting 2080ti delivered which will stress that poor CPU even more...
Something is not right there - a mate had a Core i7 6700 and went to a mildly overclocked Ryzen 2700,and had a GTX1070 and now an RX5700XT,and he has a 1080p monitor IIRC. He has not reported games having problems.
That's what I thought as everyone are reporting that gaming on 8 core Ryzen CPUs should be smooth.
Yeah could be that. Will give it a go tomorrow morning when I get home .Have you tried running the CPU at stock clockspeeds? Is the RAM overclocked?? If so try running that at stock clockspeeds. It might be an unstable overclock.
I switched from i7 [email protected] to R7 [email protected] hoping that I will be able to run a lot of programs in the background while gaming without performance hit and I have to say that I'm disappointed. Not only my average frame rate dropped (which was expected) but also I'm getting a lot of frame drops where my GPU usage drops to 70-80% and that's at 3440x1440 using 980ti..! No idea what is going on. (None of this was happening when running 6700K).
Ram is rated at 2400 and I'm running it at 2933 but it was running at that speed on Intel platform without any issues.
There's what a handfull of games the make a 4 core cpu struggle with certain settings but just do what one would do if you dont have a GPU that can push a games with all the graphics settings maxed and reduce the settings.
Its accepted to reduce settings with low end graphics cards but when its CPU's its the whole OMG 4 CORE DEAD!!!111 UNPLAYABLE STUTTER FEST!!!!
