I'm looking to build a new gaming PC (1920x1080 resolution. Not too bothered about 4K right now). My budget is around £700-800, although I'm trying to ideally not spend ALL of that, so if I'm able to buy cheaper parts which won't really be of any noticeable difference to more expensive ones, that'd be great (such as CPU, graphics card, etc). I currently have the following parts in my PC, and was just wondering whether to sell them ALL or be able to keep some of them to put towards a new build.
I also have a 750w Thermaltake Toughpower power supply. Also, the RAM I'm using is DDR4.
After looking around, I came to the conclusion that the only things that will really make a difference when upgrading from my current parts are the CPU & Graphics Card. I already have two storage drives (1 SSD and 1 SATA), a motherboard & DDR4 RAM. Granted, they are a few years old now, although I wasn't sure if they were worth using or if I should just sell them and buy completely new parts. I bought the motherboard a few years back, although it seems quite up to date even by today's standards as it runs DDR4 ram, etc.
Anyway, what do you guys suggest, and which parts would be worth buying? I was actually thinking of buying an Nvidia RTX 2060 as my graphics card, and an i5 9600K as my CPU, although I'm not sure whether I'd be better off getting an i7.
Thanks.
Thanks.
