best setup for Philips Fidelio X2HR
28 Jun 2012
Just recently bought myself a pair of Philips Fidelio X2HRs
Im using them mainly for gaming and music
My question is how will i get the most out of these headphones? plug into back of PC or i have an old astro mixamp that would be good to use because i can swap between pc and xbox
or do i need some kind of amp?
I dont have a soundcard just built in audio
Thanks
Fidelio X2 is pretty low on power requirement and with its very low impedance doesn't need much of voltage.
So it won't require any special strong output, with any better made integrated likely being good.
(they should also work well directly from controller of Xbox)
And for music no other features are needed.
Again for gaming binaural sound simulation/HRTF can improve immersion lot.
Here's stereo:
Lovely annoying inside left or right ear, or in center of the head feel.
HRTF:
First minute of this BF4 clip is also excellent quick test:
Though with above neutral bass punch of Fidelio X2 wouldn't want Dolby Headphone's (used by that Astro Mixamp) bassy sound.
I consider it just about accetaple with bass neutral headphones.
Creative has lot better balanced algorithms, after bass killing CMSS-3D of X-Fi cards.
Sennheiser gsx 1000 plus Philips Fidelio X2 match made in heaven.
GSX is still way overpriced for lack of even mid level DAC and proper amp.
And as for HRTF would expect Creative's "Project Accent" with head shape customizable HRTF to trounce others for most users.
Works well for me wouldn't change it for anything. Its in my opinion the best gaming audio experience.
Price is also subjective.
