Cheap Gaming monitors companyWho is Sceptre?
I play cs and pubg and I want most preformance from my pc. I want to have smothest gameplay possible for not mutch money.What kind of games do you play the most and how seriously do you play? i.e. do you do competitive counter-strike types stuff or single player games, etc.
My budget is 350€ and my current rig isWhat’s your budget mate? An idea of your current rig would help too.
You can get a much better monitor than a sceptre with that budget. What resolution are you after, 1080p or 1440p?My budget is 350€ and my current rig is
I5 9600k (4.9 GHz OC)
Gtx 1660ti OC
G.skill tridentZ 16gb 3200mhz
Gigabyte z390 aorus elite
With 60hz 1080p vga only Samsung monitor
I was thinking to stick with 1080p and I will use it for cs and pubg which sometimes drops to 160fps min, but csgo wont drop lower than 220 fps. My next monitor doesnt need to be ultrawide or curved.You can get a much better monitor than a sceptre with that budget. What resolution are you after, 1080p or 1440p?
Your graphics card is not enough to max out a fast refresh rate monitor unless you’re running an old title like counter strike.
I don't think 5ms is bad for any non-competitive use. Also, it's really easy to adapt to your software/hardware. I went from 0-10ping to 80-100ping at one period and performed the same after a couple of days in comp fps.
Thank you mate!! I will check more 1ms monitors and you Got it wrong with csgo, it isn't dropping lower than 220 and my gpu isn't fully overclocked to it's limit. Let's get to the point more hz with little more ms or less hz with 1ms? Which is going to be smother? 165hz 1ms is only £150-160 from sceptre which is a good price i guess!!5ms is way too high there is a reason 0.5ms displays now exist. What i would say is buy 240hz 1ms or 240hz 0.5ms.
But not sceptre... Acer Dell or Aorus etc have some For example the AW2518HF is £299. Damm good monitor as well! And 165fps to 220 is perfect for CSGO.
Alienware looks good1ms is a lot faster and there are factors like screen blur that rely on fast pixel tranistions. I was going to buy that AW2518HF myself until they released the Aorus KD25f. It would have much lower blur than the 200hz 5ms if he plays PUBG well what better proof than which monitor did the pros use in Fortnite? Well in tournaments Ninja himself used the Alienware 240hz. Tomshardware have a run down of all the calibration settings as well he would get really low blur and good colors the TN used is almost like an IPS once calibrated. And it comes in £50 below his budget also! OP will not get a better monitor than the AW2518HF for £299.
And if he wants he can easily do 4k 240fps in future with the same monitor i wrote a guide on how to do it if he searches for the kd25f thread.
