I wouldn't touch one of those and certainly wouldn't recommend one for anybody. Those units are rated at a pathetically low 30 degrees C (normal is 40 degrees C and the best units are rated at 50 degrees C) which will easily be passed in this heat. Cheap and nasty with very little quality. Don't skimp on the psu.
Could be worse, this is REALLY cheap: https://www.overclockers.co.uk/b-gr...80-plus-certified-power-supply-bg-01c-kk.html
That psu will be absolutely fine for a modest build, this comes from personal experience.
If you have the choice of either a budget psu, brand new with warranty, or spending almost the same on a used 10 year old psu, then there really is no question; the new psu wins EVERY time. Now would I recommend the EVGA one i linked to for say a 3700x and a 2070 build? Absolutely not.
Conversely would I recommend putting something like a rm850i in this build? Again, Absolutely not.
This is a £350 build mainly using used parts, that is EXACTLY what a budget psu is intended for. If Chris Beard wants to get a higher quality psu, then that's completely fine (and recommended), however to do that on a £350 budget doesn't appear to be possible.
Now you are just finding the worst psu on here to make your choice look good.
The way I read it is that the 1200 is a stopgap and he is looking at putting in a 3600 further down the line. If he buys a decent quality psu now it will outlast this build and can be used in the upgrade or even the next build. You don't have to spend £100 to get a quality psu. The Bitfenix Formula Series 550w is only £66.95 and would have been my recommendation. That's a gold rated psu with decent quality internals and a 5 year warranty. However, a even better psu is in the "this week only" deals in the form of the not long released Superflower Leadex III 550w at only £64.99. That is a excellent quality gold rated psu that is fully modular and has a 7 year warranty. At that price it's a steal.
I will only ever recommend a component that I would be 100% happy to use myself and cheap psu's will never make the cut. The psu is not a place to save money and should never be skimped on. These cheap EVGA psu's are usually built by HEC (very little information on this series yet) who don't exactly have a good reputation for building a decent psu. Several of the other cheap EVGA psu's have been very unreliable and that is yet another reason why I would never recommend one.
Haha, does it work though? That's the main question?I got the cheap second hand one! Had a look at some articles where they retested after 7 and 10 years of continuous service and made up my mind.
Running for 2 hours prime @ 3.8Ghz 1.35v so far
Really loving my new machine.
One thing no-one picked up is that the cooler (even though the product page says otherwise) isn’t AM4 compatible.
If my choice of PSU had you worried you’ll be downright panicked at the cardboard shim, half-the-screws not used makeshift mounting I used!
Gigabyte GA-AB350M-DS3H Micro ATX AM4 Motherboard (£38 second hand)
The MSI Tomahawk Max which has Ryzen 3xxx support is now available.
Build log please!If my choice of PSU had you worried you’ll be downright panicked at the cardboard shim, half-the-screws not used makeshift mounting I used!
whilst you are indeed correct, the board you've chosen has trash VRMs and so wouldn't support anything except the entry level ryzens.Let me know if I misunderstood please.
Build log please!
