I'd imagine your options goes along the lines of the following (for best cooling and noise ratio, without factoring in price):
1. Kraken G12 + AIO
Pro: Looks clean, temps are diverted away from middle of case via AIO, and highest level of cooling obtainable (other than going custom water).
Con: Possible Compatibility issue (check online for other success stories using same GPU and setup), Possible Water Pump noise, depending on fans on the AIO - possibly fan noise too, depending on AIO (possibly) not cheap, and finally the possibility of leaking from the AIO (causing damage).
Price: ~£120 here at OCUK depending on which is bundle/aio is chosen
2. Morpheus + Decent Fans
Pro: Good temps, and only Fan noise to contend with (which is controllable via software/bios).
Con: Fairly expensive for Morpheus kit + fans, Morpheus incompatiblity with GPU (kit may not have all parts needed to cool your GPU passively), needs decent case airflow, and more disassembly and assembly than other options.
Price: ~80-120 here at OCUK depending on which fan is chosen along with morpheus HS.
3. Remove GPU Shroud (leave Heatsink on) + Noctua Fans (Or other fans suitable for your ears; just make sure they're big enough for your GPU native HS) + Cable Ties (Zipties)
Pro: Only needs Fans, possibly maybe a GPU to PWM cable to control fans on GPU software, easy to replace, and (relatively) cheap
Con: Ghetto, not really photogenic, possibility of ties breaking (and fans breaking off) if using poor ones, and needs decent airflow for intake and exhaust (as fans blow hot air into the case)
Price: ~50-60 here at OCUK depending on which fans is chosen
These are the same options I had for my Powercolor RX580 Red Devil, but I found that option 1 wouldn't work because the PCB was incompatible (VRMs were not covered by the Kraken and no easy placement for a fan to cool it that way either. So that prevented option 1 for me. Option 2 had the same issue, the Morpheus HS wasn't compatible, so I was forced to go with option 3. And surprisingly, option 3 wasn't that bad.
