I have an unusual requirement here.
I need a card with a big cooler to sit in a room that is above normal temperatures.
I was looking at a Gigabyte 2070 Super Gaming and the Aorus 2070 Super. Now the Aorus runs hotter than the Gaming so it may seem mad that I am even considering it, but since it has a much bigger cooler and fans I assume that's just because it's overclocked. Obviously I can change the fan curves but the biggest gain should be if I can clock the Aorus at the same clock as the Gaming. Gigabyte software usually offers the option to run the card in several overclock modes so I was thinking if I select one of those modes then it "should" run cooler than the Gaming. Problem is that I don't know for sure. I also don't know whether this is strictly true with Gigabyte cards that selecting a different mode will in fact reduce the temperature. Is it possible for example they are running it at a higher voltage consequently it's impossible to actually reduce the heat as much as I would like? I have no idea how this works. Can anyone shed any light on this? I have never attempted to underclock a graphics card so have no idea, lol.
