Would benefit from the addition of a front 140mm fan if you bought that one - to help with airflow.
That was quick - I was just looking into the case - but seems you were working within a budget and if you like the look it's a solid, budget case to hold your components.Ordered <3
Speak for yourself lolsomeone is usually lurking (all hours).
From the site:does the graphics card have 2x hmdi ports? i think it does but hard to tell from the site pics xD
You're a fellow vampire - regardless of shifts/jet lag effectSpeak for yourself lol![]()
Display ports - you can use adaptors.okay i have no idea what the 1.4 display port is haha
