tuff gamming x470
Permabanned
7 Aug 2017
by the tower the one up north ..
ok doing my head in can't get this stable at stock .
tuff gamming x470 latest ab bios
team dark 3600 cl16 mem
amd 3600
no matter what I do I get random crashes??
only thing I have notice is there are 4 flags on pci device in device manager ?
now I have tried running mem at 2400-3600 with voltage up to 1.4.
memtest came back ok ?
how can I find out what those things are in device manager .. ?
the only thing hooked up is keyboard mouse network cable and a hard drive Samsung ssd
can't figure out what they are ?
used the asus one then the new one on amd site ..
The latest ASUS chipset driver 1.7.29.0115 looks like it includes the latest AMD update, but it's prerequisite is that you need to:
- Update AMD chipset driver 19.10.xx first before update this driver
What I'd try is to install the following from ASUS website and in this order:
  1. Chipset driver version 19.10.22
  2. Chipset driver version 1.7.29.0115
If you bought the motherboard from OCUK, yeah probably worth asking them what those unrecognised devices are and what drivers are needed, then take things from there.
I have a similar issue on the Strix X470-F following the BIOS update to 5007 and subsequently 5204 and it won’t POST at anything other than 2400MHz Auto following the BIOS update. I have the same 3600Mhz CL16 kit as you, which was stable at 3200MHz at 14-14-14-31 on my 2700X prior to the BIOS update to 5007.
I have been advised by Asus to RMA the board through their tech support.
Running latest Chipset drivers.
well after 2 emails they said rma it to ocuk ? ...
they can't understand the flags on device manager ?
only thing plugged into the board=
keyboard mouse and hd ...
Sorry probably a little late, the the PCi encryption controller and PCI device could be related to the TPM module, did you enable it by accident in the bios ?
The other one is a USB controller, not a device as such.
not that I know of .. even on bios defaults it's there ..
so if it's on by default I would not know where to look ..
