No power in the grid = no power in the cell sites.
Yup
'This has been a preview of life after hard Brexit. Beloved Leader Boris Johnson thanks you for your time.'
I heard we are going back to candles and outside toilets.![]()
There is enough generation.No power went out here.
This type of thing was inevitably going to start happening when the government in the past refused to allow a new power station to be built. We're on the verge of being underpowered.
The issue yesterday was caused by two large generation sources disconnecting off the electricity network at the same time (within 2 mins of each other which is highly unusual), causing a dangerous drop in frequency, which triggered the National Grid safety systems to keep power working for the rest of country.
- There is always enough reserve generation ready to kick in- it’s a mandatory requirement. Also, the loss yesterday had nothing to do with a lack of generation.Two power stations disconnected from the network leaving it unable to provide "enough generation". They then chose to cut off power in many parts of the country including to hospitals and the rail network.
The question as to be asked is why did the two power stations disconnect from the network? It also shows how little reserve we have. This needs to be increased.
We need new nuclear power stations to be built.
https://www.theguardian.com/environ...-stations-in-doubt-over-ageing-infrastructure
What I genuinely don’t understand is why, if the power was off for only around 30-40 minutes, was there such disruption for so many hours after, especially with the trains?
Is just a matter of the time it takes to get signalling system etc back up and functional?
I can understand a delay in timetabling, but not so much the hours people were stuck on trains.
My Mrs was working at TGI Fridays on the oaks and got to go home!Ellesmere Port and Little & Great Sutton were definitely out. I found power was ok at the A41 Backford lights heading towards Chester as I was following the ambulance containing my wife (all ok now, but a stressful late afternoon !)
British made outside toilets..... true grit.
