rsync help
16 Jan 2006
North Wales
Hi
am looking to backup a web server online to a home server at home using rsync (data only)
i have run the following command
rsync -v -e 'ssh -p 2222 root@"IP":/root/home/clickit/*' '/home/backup/' (change the IP to the ip of my server)
i get the following back, i was waiting for a prompt to enter the server password really.
building file list ... done
drwx------ 98 2019/02/12 16:40:12 .
-rw------- 79 2019/02/12 16:40:12 .bash_history
-rw-r--r-- 18 2018/10/30 17:07:12 .bash_logout
-rw-r--r-- 193 2018/10/30 17:07:12 .bash_profile
-rw-r--r-- 231 2018/10/30 17:07:12 .bashrc
drwxrwxr-x 6 2019/02/12 16:38:04 sheldon
sent 140 bytes received 371 bytes 1,022.00 bytes/sec
total size is 521 speedup is 1.02
All it has done on the backup rsync server is created a folder called sheldon - sheldon is the host name of the web server.
Any idea's what i am doing wrong?
Thank You
13 Jun 2007
London
Looks like you need to add -r option to recurse through folders.
I like to use -a option for archiving when using rsync for backups. It includes the following:
Code:
-r, --recursive recurse into directories
-l, --links copy symlinks as symlinks
-p, --perms preserve permissions
-t, --times preserve modification times
-g, --group preserve group
-o, --owner preserve owner (super-user only)
-D same as --devices --specials
--devices preserve device files (super-user only)
--specials preserve special files
3 Oct 2013
I use
Code:
rsync -r -t -v -P -e ssh /source user@server/destination
This is what I use to do a backup from my desktop to server. I use ssh with a key file as saves messing with passwords for this particular task.
OP
16 Jan 2006
North Wales
rsync -zavP -e 'ssh -p 2222' root@IP:/root/home/clickit/ /home/backup/
Sorry for the late reply only just got back on to this project.
That worked perfectly thank you. what is the zavp -e for? new to rsync sorry
I use
Code:
Do you know where i can learn about key files?
16 May 2008
Bristol
-z, compress file data during the transfer
-a, archive mode; equals -rlptgoD (no -H,-A,-X)
-v, increase verbosity
-P, show progress and keep partially transferred files if interrupted
`man rsync` will give you loads more details
OP
16 Jan 2006
North Wales
Sorry to come back to this after such a while but i have 1 more question if anyone can help -
rsync -zavP -e 'ssh -p 2222' root@IP:/root/home/ /home/backup/
When i do this it asks for the root password of the server. I want to turn this in to a cron job but it will stop on the password screen wouldnt it? i want to set up a cron for 3 times aday but how can i get around it asking for the root password? do i add something to the command?
5 Nov 2011
Derbyshire
If you set the SSH keys up you won't be asked for a password.
SMN
SMN
2 Nov 2008
The ether
What Steveocee said :D
Also, Can I make a point of using a user rather than root !
I have to reiterate this, x1000.
Few things to do:
1. On all boxes, set 'PermitRootLogin no'.
2. Use keys to login, not passwords: From the box you want to login FROM, run 'ssh-copy-id bilbo@server -p 2222' and login using the password. After this, you can simply 'ssh bilbo@server -p 2222' and you are in. Then you can go ahead and disable password login entirely, or not if you dont feel comfortable.
3. Use SSH config to your advantage: If you are using rsync and the like, non-standard ports are generally a faff. I always use SSH config to bypass this; edit ~/.ssh/config on the box you are SSH'ing FROM and add something like:
Code:
Host server
    HostName 192.168.0.254
    Port 2222
    User bilbo
Afterwards, you can simply 'ssh server' and you are in (if you did my step 2, above).
That then potentially makes your rsync command a lot simpler too, as you enter less params.
HTH.
10 Oct 2005
Nottingham
I agree completely with not using the root user to connect remotely, but if the OP does make this change they should remember to check that the user which they are connecting as does have the access required to be able to transverse directories and read the files which are to be synced. It may have worked as root previously but random other user may not be able to access the source files.
