Permabanned
- 9 Jun 2009
- London, McLaren or Radical
5.4, nice! De-lid?
No need... temps are good under water
Got lucky... just a retail box item... did get it from ocuk too
5.4, nice! De-lid?
I think der8auer delidded the 9900K and it didn't reduce thermals all that much. But he seemed to get measurable reductions in temperatures by lapping the die itself to reduce the die thickness. I think it's probably going to be too extreme for most people to want to bother though.Does anyone actually do it apart from der8auer.? Those CPUs are soldered so there is not much to gain from deliding.
Exactly...I think der8auer delidded the 9900K and it didn't reduce thermals all that much. But he seemed to get measurable reductions in temperatures by lapping the die itself to reduce the die thickness. I think it's probably going to be too extreme for most people to want to bother though.
I see, thanks for the insight. Does the 9700K have improved solder too?
The 9700K would have similar solder to this:I see, thanks for the insight. Does the 9700K have improved solder too?
What average temps are you hitting at 5.2 under load (not synthetic).I have mine on direct die so yes some of us crazy enough to![]()
All 9900k do 5.0 mate. Lottery would be 5.3 or 5.4i9 9900k....
5ghz all cores - 68c @ 1.168v - stressed @ full load over 10mins
Never won lottery before - well pleased![]()
Its not just about speed but how many volts you need to get there.
..by any stretch he has a very good 9900K to get 5Ghz at those kind of voltages, most need well over 1.3vlts to achieve it.
Anyone who gets a plum 9900K clocker now is doubly lucky because Intel is almost certainly binning and holding back the best ones for the upcoming 9900KS edition.
Huh? I thought 5ghz 9900k was normal?
I must be very lucky![]()
