I'm nowhere near new to this but I've been out of the loop a long time so I am somewhat lost... Years of macs and NUCs has gotten me out of the loop.
I'm being brought back to PC gaming due to my unwillingness and inability to use a pad plus wanting to play some proper FPS stuff.
that and the fact I've managed to bag a 2070 super FOC
Anyway.. I've got a few criteria and I'm interested in what the experts would suggest I went with now..
The requirements:
Case: Smallish - it's going to live on a desk, ideally inverted as it will live on the left so a window on the left would be useless for now although I am moving so this is minor. I am quite taken with ITX/MATX though. Has to be classy though, I always used to build in things like Lian Li, I most prefer a simple box, clean lines etc. I had considered NZXT stuff, looks pretty boxy and black, I like that but what's the suggestion nowadays?
CPU: Not crazy money, mid range overclockable CPU but not stuck on intel or AMD, I'm a "pro" of nothing. Light basic office use and then light gaming, I won't be benching or editing anything or whatnot.
Mobo: Similar with mobo but want it to look good, I gather RGB is a thing nowadays? Also I like to make colour matched stuff so for example all black and orange or similar. Decent audio, built in wifi and ethernet and ideally NVME slots preferred.
Ram: I guess 16gb, again ideally RGB I suppose.. again I'm taken with the fact you can get pointless dimms that just have the lights, i like that!
Cooling: I used to be deep into custom water, not sure I can bothered now and I'm a bit freaked by the whole hardline thing that's happened since I stopped.. Maybe AIO? That does leave the 2070s though which I always remember the GPU being the noisy but and quiet is an absolute must as it'll likely be on 24/7.. or do I just man up and do custom water with soft tubes or even worse.. take the plunge all the way?
PSU: Fully modular, not overspecced, I'm never going to SLI etc
Is that it? It's mostly the case I'm stuck on.. I was thinking about a Phateks Enthoo Elvolv Shift but I'm not convinced the GPU cooling is up to it and I guess I can't do dual AIOs? Is there even a 2070s AIO?
So what I don't need: Windows, a screen, GPU, storage, peripherals.
No defined budget, I'm just not planning to go mental with anything.
HALP!
The requirements:
HALP!
