immune system stops it before it multiplies or spreads.
"Atwater system"As far as I know, food calorie values are based on their actual energy content. Specifically, 1 food calorie is the energy required to raise the temperature of 1Kg of water by 1C. The figures were originally obtained by literally burning a sample of the food and measuring the heat generated. Nowadays, it's done by analysing the broad nutritional content of the food (e.g. how much fat, how much protein, etc) and using standard values for each. There's some debate about how accurate this simplified approximation is.
On a personal basis, the figure I've seen mentioned for the variation in efficiency of digestion from person to person is 10% (outside of a medical disorder affecting digestion). Probably also an estimate - how can it be accurately measured?
"Atwater system"
I've googled it to check my memory. It does indeed take into account loss through the human digestive process. For food ratings on packaging (and standardised ingredient ratings) - obviously you can't derive more calories from a foodstuff than the absolute calorie value, but you probably can get more than the amount listed on the packet, if you happen to have a digestive system that is more efficient (?) than the norm.
Depends what it is, for example if you eat 1000 calories of protein, it's very expensive to metabolise so whilst you put 1000 calories worth of food in your mouth, it actually requires up around 20% more energy and heat to metabolise than say, carbohydrates. So eating protein is actually a workout for your digestive system.
Another one is gut bacteria, depending on what you're actually eating - a larger or smaller proportion of those calories actually end up being metabolised by your gut bacteria not you, depending on what you eat.
This is another reason why calories from junk food can be far worse than the same number from normal food, because there's a growing body of evidence that shows how the emulsifiers used in processed food can harm gut bacteria.
I'm afraid only you think its a conspiracy. Because that IS what all the health experts were saying back in the day, that it was down to smoking. Why do you think you hardly see any tv series or movies with actors smoking these days? Because TV was blamed for glamorising smoking and causing cancer.
Agree 100%. Happiness is healthiness.
Protein doesn't require 20% more energy to digest, where did you even read this?
Protein takes the most energy to digest (20-30% of total calories in protein eaten go to digesting it). Next is carbohydrates (5-10%) and then fats (0-3%).
Calories are not created equal. First, some foods (in particular, proteins) take more energy to chew, digest, metabolize, and store than others. Others (such as fats and carbohydrates) require fewer calories to digest and store.
Different types of food require different amounts of energy to process, according to WorldFitnessNetwork.com. Fats have a thermic effect of about 3 percent. If you consume 100 fat calories, only 3 calories will be spent digesting the fat. Fibrous vegetables and fruit have a thermic effect of about 20 percent, while proteins have a thermic effect of about 30 percent. If you eat 300 protein calories, you'll burn off 90 calories digesting the protein.
Both dietary carbohydrate and protein provide the same amount of available energy, 4 kilocalories per gram, but it takes about 25% more of that energy to process protein.
Why do people believe such crazy myths around specifically nutrition? It must be the subject with the most people talking the most uninformed rubbish out of any other subject.
Protein doesn't require 20% more energy to digest, where did you even read this? 1g of Protein is worth 4 calories, 1g of Carbohydrate is worth 4 calories. There's no such thing as a "work out for your digestive system" lmao. You've honestly just typed a complete load of rubbish. Why do people believe such crazy myths around specifically nutrition? It must be the subject with the most people talking the most uninformed rubbish out of any other subject.
The thermic effect of food is the energy required for digestion, absorption, and disposal of ingested nutrients. Its magnitude depends on the composition of the food consumed:
Are you seriously arguing with me that smoking doesnt cause cancer?
