Hi
I am currently running the rig in my sig.
On stock settings my cpu goes upto 1.5v and mid to high 50's during gaming which I think is rather high for a cpu being cooled with a ekwb custom loop with a 360 rad.
I can run this cpu at 4.3oc on all cores at a voltage of 1.325v with offset at turbo setting so goes up to 1.35 under load and the cpu is mid to high 40's during gaming.
I have read that a ot of people say it is no point manually overclocking the 3700x as the gains are not massive etc etc
My question is is it ok to run my cpu with the manual oc for everyday use or am i harming it by having a manual voltage of 1.325 all the time or is there a better option with my set up
The temps in the dynamic case are not brilliant and my gtx1080ti was getting upto 84c during gaming and I have been trying different configs with the raditor and fans to see if I can get better temps and I am now with a top mounted rad with fans dragging air out of the case through the rad and 3 side fans and 2 bottom fans as intake, this as helped the gtx as i am at 75c during gamingnow so much better.
Any views or ideas would be most appreciated
