Quiet (silent?!) air CPU cooler for Ryzen
31 May 2006
Hi all
Got a Ryzen 5 3400G and using the stock cooler (no overclocking) and it absolutely drones on even at low load! Can someone please recommend an air cooler that is very quiet (possibly silent at low loads)?
Thanks
HeX
HeX
20 Jun 2004
Huddersfield, UK
OP
31 May 2006
https://www.overclockers.co.uk/cooler-master-hyper-212-black-edition-cpu-cooler-120mm-hs-081-cm.html
Good cooler for the money, will be considerably better than the stock heatsink, limit the fan speed to whatever you feel comfortable with and job done.
Or if you don't mind spending the cash, you can't go wrong with the Noctua coolers.
https://www.overclockers.co.uk/noct...lim-cpu-cooler-with-nf-f12-fan-hs-025-nc.html
Silly noob question but I've seen install videos that show fitting a bracket to the back of the motherboard but I screwed the stock cooler straight on without adding anything? I don't want to pull my motherboard completely out, would I be able to screw say the Cooler Master into whatever I have my stock cooler screwed into? Thanks!
HeX
HeX
20 Jun 2004
Huddersfield, UK
I would imagine you'll need to use the CM back plate that comes with the cooler. Does your case not have a cutout behind the mobo to allow access to the CPU backplate?
1 Jul 2011
Hi all
Thanks
Are your temps high just because you OC'ed with stock cooler or is the air temp inside of case going into cooler much warmer than room air? This is a common problem when users do not setup case airflow properly. If you are interested, below link is to basic guide to how to optimize case airflow.
https://forums.overclockers.co.uk/t...-i-put-my-temp-sensor.18564223/#post-26159770
Would help if we know what case and mobo you are using. While 212 is an okay cooler, there are better ones at similar prices. .. like Alpenfohn Brocken
https://www.overclockers.co.uk/alpe...ion-dual-fan-cpu-cooler-140-mm-hs-05f-al.html
OP
31 May 2006
Just checked and yes it does, thanks for that! Does the old plate just pull off?
No as stated in my OP no overclocking and I have no plans for overclocking either. This is my work PC mainly and I don't want to listen to the fan drone on for 8 hours per day!
Case is AvP X6 Mid Tower Gaming Case and motherboard is a MSI B450 GAMING PLUS. Not sure you'd call 32 deg C idle as high either?
1 Jul 2011
The bigger the cooler the slower it's fan and case fams need to run so the quieter it is.
With my 6700 rendering graphic at about 80% load is so quiet I can't hear it a meter away.
6 Jun 2008
Finland
That's exactly the wrong choise for return on money when it comes with also acoustically mediocre fan. (powered by inbalanced internal combustion engine as motor maknig it vibrating roller)
Scythe Mugen 5 is class better for cheaper price.
https://www.overclockers.co.uk/search?sSearch=mugen+5
That depends on particular cooler.
Some use their own backplates.
Scythe's mounting uses default backplate of AM4 boards.
ftp://ftp.scythe-eu.com/Manuals/CPU-Cooler/Mugen-5-Rev_B.pdf
1 Jul 2011
Ok so the extra 20mm is what makes the difference here?
It's a combination it being a well constructed cooler with more fin surface area and more heatpipes. Not so much fan size, but yes, 140mm fans can move more air at lower speed than similar 120mm fans, so are usually quieter .. but not always. Tower coolers do a better job of moving heated air back and out rear exhaust and thus keeping from mixing and warming up the air coming into cooler .. and ever degree cooler the air into cooler becomes same degrees cooler CPU will be at same airflow rate/fan speed.
OP
31 May 2006
1 Jul 2011
Thanks for the recommendation on the Alpenfohn Brocked.... I should however have checked the size of the damn thing!! It is about 2cm too tall for my case :eek:
Have you installed it to see if case will close? Often case companies say CPU clearance is a few mm less than it actually is. Could just set cooler on CPU and try closing case. It just might fit .. assuming you have it.
OP
31 May 2006
Pity the Alpenfohn Brocken 2 PCGH Edition Dual Fan CPU Cooler - 140 mm doesn't fit in your case.
However, I thought that cooler needed the Alpenfohn AM4 Mounting Kit for Brocken Coolers, unless the AM4 mount is now being included already with the cooler.
I ordered the AM4 mount with it.
Not yet but I'm very sceptical that it will fit. Just offering it up to the front of the case it is almost as wide.
OP
31 May 2006
Fitted and it is very quiet and very efficient, 29deg C idle, 50deg C load vs 70deg C for the stock cooler. However it is about 3mm too tall to fir the case side. Doh.
