- 6 Feb 2019
so ive up't the budget a bit and come up with this, i have a few questions.
will it run games on a 1080p 144hz monitor like the new call or duty , and other first person shooters, on decent settings?. hes upgrading from a i5 4670k and gtx 770.
do i need the extra cooler ? the stock prism looks great and if poss would like to use it, and save a few quid.
the B450 pro carbon is out of stock everywhere, should i go for the tomahawk max or spent a little extra on one of the cheaper x570s? motherboard selection is doing my head in, i dont want to be stuck in the future for upgrading if i want to throw in a newer CPU or GPU. it seems a good B450 or a bad x570 are my options.
any reviews on the 2070 super, is the MSI one a good choice, or are other brands better. ?
and if anyone thinks my parts list is crap and wants to help with a better one then please do, budget is £1500 , can go slightly higher, i would prefer lower , i just needs some RGB and a nvidia GPU. there his only set in stone choices. any help appreciated. thanks
My basket at Overclockers UK:
- 1 x NZXT H500 Midi Tower Gaming Case - White Window= £69.95
- 1 x AMD Ryzen 7 3700X Eight Core 4.4GHz (Socket AM4) Processor - Retail= £319.99
- 1 x MSI GeForce RTX 2070 Super Ventus OC 8192MB PCI-Express Graphics Card= £539.99
- 1 x Corsair Force MP510 series 960GB NVMe PCIe M.2 Solid State Drive (CSSD-F960GBMP510)= £149.99
- 1 x Seagate 2TB BarraCuda 7200RPM 256MB Cache Internal Hard Drive (ST2000DM008)= £55.99
- 1 x Corsair RM Series RM650 650W '80 Plus Gold' Modular Power Supply (CP-9020194-UK)= £76.99
- 1 x Corsair Vengeance RGB PRO Black 16GB 3600 MHz AMD Ryzen Tuned DDR4 Memory Kit= £128.99
- 1 x MSI B450 TOMAHAWK MAX (Socket AM4) DDR4 ATX Motherboard= £106.99
- 3 x Arctic Cooling F12 PWM Fan Rev. 2 - 120mm= £4.99
- 1 x Phanteks RGB LED Strip Starter Kit (PH-LEDKT_CMBO)= £13.99
- 1 x Arctic Freezer 34 eSports Duo White CPU Cooler - 2 x 120mm= £29.95
Total: £1,520.99 (includes shipping: £13.20)
