except @tamzzywho also suffers from the same affliction as yourself - but bypasses general public interaction by inducing his patients into a coma.
You still have to endure them for 30 seconds to a minute before onset - you need better product![]()
Luckily for our ICU reg Mr. @tamzzy most of them are already/near comatose by the time they get to him, he just tops them up every so often so they don't wake up and start bothering him
.The Zotac should still stay as the white sleeved cables will act as the focal point - would be happy accident if it lit up in white, haven't checked. Plus, shade/shadow/contrast can be equally effective as you've probably seen from other builds.
I prefer 3700X as an option as I suspect you may delay upgrading due to life commitments and this being a brief flirtation rather than a hobby. i.e. once built out of mind - plus, money will be a novelty for a while, so spend what you have now![]()
No issues with the Zotac but it's unfortunately out of stock, so i've got the Gigabyte you recommended earlier in the basket instead. And agreed about both the 3700X and the money being a novelty!
Some updates on my copious reading/research into the world of RGB. The main consideration was the NZXT architecture vs the Corsair. I'm pretty sold on the Kraken, the infinity mirror really just does it for me. From what I understand, there's then an issue of USB headers, because you have the AIO, and then when you swap out the rear and top stock fans for RGB ones you don't have enough headers or you can't control the lights/fans or something. So people typically get
this:
or this:
- 1 x Corsair LL120 RGB, 120mm Dual Light Loop RGB LED PWM Fan, 3 Fan Pack with Lighting Node - White= £89.99
Since they have the Hue 2/Lighting PRO management thingies which only takes up one USB header. When I compared both, going with Corsair:
++ The fan bracket itself is white
+ RAM is Corsair RGB so would sync on the same system as the fans
+ Apparently the Corsair software is better than the NZXT
+/- The fan blades are illuminated, as well as the halo on the outside
- £90
- 3 Pack of fans, and I only need 2 (for rear/top)
Going with NZXT:
+ AIO is NZXT so syncs on the same system as the fans
+ £72 so cheaper
+ 2 pack of fans
+ If I decide to convert the radiator fans to RGB, or add an LED strip it would be a like for like swap/addition on the same system
+/- Halo ring light only
- NZXT software apparently not as good
From an aesthetics point of view I really can't say one set of fans looks better than the other. I'd really welcome some input on this to sway me one way or the other.
Here's where we're at currently:
My basket at Overclockers UK:
- 1 x NZXT H500 Midi Tower Gaming Case - White Window= £69.95
- 1 x AMD Ryzen 7 3700X Eight Core 4.4GHz (Socket AM4) Processor - Retail= £319.99
- 1 x MSI B450 TOMAHAWK MAX (Socket AM4) DDR4 ATX Motherboard= £106.99
- 1 x Crucial MX500 500GB 3D NAND Sata PCIe M.2 Solid State Drive= £59.99
- 1 x Seagate 2TB BarraCuda 7200RPM 256MB Cache Internal Hard Drive (ST2000DM008)= £55.99
- 1 x Seasonic Focus Plus 650W 80 Plus Gold Modular Power Supply= £94.99
- 1 x Gigabyte GeForce RTX 2070 SUPER Gaming OC 8192MB GDDR6 PCI-Express Graphics Card= £548.99
- 1 x Corsair Vengeance RGB Pro 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - White= £99.95
- 1 x CableMod PRO ModMesh Cable Extension Kit - White= £44.99
- 1 x NZXT Aer RGB 2 Fan with HUE 2 Controller - 120mm Dual Fan Pack= £71.99
- 1 x NZXT Kraken X62 AIO Water Cooling Unit - 280mm= £139.99
- Thanks to @tamzzy and @Plec 's eternal wisdom, the motherboard has 2x M.2 Slots, so I can save money and have my spacious 500GB SSD for now, and always throw another 1/2TB one in down the road if I ever have need of it.
- 16GB RAM rather than 32GB because even though I think 32 would be better and worth the extra price, i've seen reports that it's extremely tight/not possible to seat the Kraken AIO horizontally with 4 sticks, and having it seated vertically looks stupid imo.
- I had a look for a 650+W Gold PSU in white that would mean not needing the £45 white extension cables but it doesn't seem to exist.
- Swapping the 3700X for a 3600 would change the total to £1482.81. Is it a pain to unplug an AIO to change a CPU? Removing fans and unscrewing the backplate of my Prolimatech Megahalems was akin to torture - but it's been 10 years of development. If it's easy to do, I wouldn't be opposed to a straight CPU swap in a few years if needed, especially since I recall AMD have promised to keep the same socket until 2022? We're well under budget either way.
- NZXT fans + HUE 2 placeholder until decision on the above
- Tempted to get one LED strip because the H500 doesn't come with any but left it out for now, I want some degree of tastefulness
