- 17 Sep 2018
It only has 4cores, yep it's your cpu in the games that make use of more threads.
The R5 2600 in that video is quite weak, especially at that clockspeed but still shows a big difference in fps and gpu utilisation, when the cpu utilisation is too high. The difference between the cpu's would grow if the vega was clocked and tweaked properly.
The gpu was probably returned for either the coil buzz, or poor clocker, but i'm sure it'll be fine when you upgrade to an R5 3600![]()
Yes, my research yesterday does point to that
https://www.techspot.com/article/1803-are-quad-cores-dead/
If you look at 7:45 you can see you can see on Shadow of the Tomb Raider going from a 1060 to a 2080ti gives no performance gains with a 2200g.
You can also see their Hitman benchmark mirroring the issue I had. Although the 2080ti did manage minimums of 40 fps with a 2200g on Odyssey so it isn't just the CPU in that game.
Today I am downloading Forza 4 on Xbox Pass because it isn't CPU limited and compare to other benchmarks. Then I choose between second hand 1700/1800x and a new 2600 if it's handling Forza as it should. Actually I think I need to upgrade the 2200g even if I keep the RX 580
