- 22 Feb 2014
We have a 5 year old integrated lamona (Howdens own brand so probably a beko ) fridge/freezer.
The freezer is working fine (not checked temp but everything looks ok)
Fridge only gets to about 10oc on highest setting, but I've just emptied it and ice had built up on the back near the top on one side
I've pulled the unit out to have a look at the back
No fan, single condenser.
The condenser is red hot, can't touch it for more than a second, the coolant pipes all seem to be mildly warm to the touch, apart from the ones near the condenser unit. I can hear the condenser running, and occasionally can hear the sort of noise when you have air bubbles in a water cooling loop.
I can't feel any cold lines or see any condensation anywhere.
What is broken?
Is it fixable?
Is it worth fixing or should I just replace?
If it needs replacing I'm going to try and order one for delivery tomorrow.
What is broken?
Is it fixable?
