new Shower issue
2 Oct 2007
Winchester
Hi All,
We have recently renovated an old bungalow to live in. as part of this we built an ensuite. We finally moved in this weekend but we are having issues with the shower. for some reason its not getting hot the water only runs through cold regards of what we do with the controls (bar mixer shower) the hot taps for the same bathroom run hot its just this shower that is having problems.
any idea's on where to start to diagnose the problem?
OP
2 Oct 2007
Winchester
So the hot taps run cold, as does the shower?
The taps are fine, they run hot just the shower that the issue
Sounds like the thermo could be borked, or the hot isn't working at all as its blocked or something, can you check the flow of the hot is making it to the shower?
the hot tap in the ensuite is on the same line as the shower, i can go into the roof and try and feel the pipe later to see where it stops feeling hot. hopefully i dont need to replace the shower :(
4 Aug 2007
Wilds of suffolk
So whats the actual flow, hot to tap then on to shower? Is there an isolator or anything that could be off so no hot can get that far?
If the thermo is broken (actually check the shower is actually set to hot to start with!) then no hot will flow so the pipes wont warm up.
What I meant was can you get to the hot as it comes into the shower itself and test the water there is hot. Could be a pain, but if the water will flow to there hot then the issue is the shower.
Did you fit it, or did someone else fit it?
OP
2 Oct 2007
Winchester
This is the shower - https://victoriaplum.com/product/orchard-eden-round-thermostatic-exposed-mixer-shower
as far as i can see there is no isolater in the roof. our builder is in the roof and its a pretty simple setup. hot from the boiler splits goes down to 1 bathroom and from there to the kitchen and then from the boiler it goes to the ensuite.
i will feel to see if the pipes are getting hot later and see where its stopping, but i have a feeling its the thermostatic shower mixer that is broken :(
edit - our builder fitted the shower.
Caporegime
13 May 2003
Warwickshire
My best guess with us still not knowing what system the op has, is that the mixer is broken, but this is fairly unlikely. It's possible there's an isolation valve on the hot supply that's accidentally been left closed.
So do you have a combi boiler and the hot water all runs off the combi?
25 Sep 2016
I had the same issue after my bathroom was done
I had to adjust the thermostatic mixer by taking the knob off and winding the cartridge back and forth so the 120deg or so twist moved it in the correct range.
Strangely enough this wasn’t in the instructions or easy to find about on google
Edit: this
https://youtu.be/baemm_xNaak
OP
2 Oct 2007
Winchester
In a way thats easier to start diagnosing, switch it fully to hot, turn on the shower, does the boiler kick in?, it should as it should sense demand for the hot water.
Mercenary actually has a really good suggestion above. My guess would be it's been plumbed in incorrectly!
Edit: this
Thanks for the idea's after spending some time in the roof shouting at the wife to turn various things on and off it looks like the builder as plumbed in the hot and cold the wrong way into the shower... will need need to swap them over, thankfully they are plastic push fittings so shouldnt be too hard to do.
4 Aug 2007
Wilds of suffolk
Good(ish) news :) It annoys me that trades can mess this sort of thing up, an DIYer yeah sure, but someone who does this for a living shouldn't make schoolboy errors.
I would call them back personally, say you think this could be the issue as the shower isn't working and get them to fix their error
As soon as you start messing with it they will potentially wash their hands of any other issues.
OP
2 Oct 2007
Winchester
yeah i have done, left them a couple messages last night and they are going to be sending someone over tomorrow to sort.
Thanks again for the help.
25 Sep 2016
I thought the same, but until the thermostat was adjusted hot water was never being "asked for" by the shower - only took 10 mins
