- 12 Feb 2006
- Surrey
we're looking to possibly get our boiler replaced (in fact we're having new rads, boiler moved to loft, new water tank moved to loft etc), and one thing the guy has included in his quote is smart controls
i've asked for more from him on this, and below was his explanation
i then told him i'm wanting a nest system, and a boiler that is opentherm enabled. i've had 3 plumbers quoted before and all had no clue what opentherm was, so i linked him to this and he came back with the following:
and i reconfirmed about opentherm as i didn't think he got it and he said this again
can someone explain to me, as from what i understood, opentherm is something the boiler either can do or can't? so it's not something that is fitted onto a boiler?
also the system he's suggested above, i've never heard of it. is it something that's needed so we can then use nest, or is this an alternative to nest? I know I can speak more to this guy, but trades men have a tendancy to just agree with whatever you ask for while quoting, but then at a later date you're screwed if it's wrong.
finally, as we're getting all new rads, new boiler, new hot water tank, is there any other smart controls we should look to include? are individial controls on each rad possible?
The smart controls are priced on the Drayton Wiser 2 zone with optional Trv individual room control.
The Trv heads were not in the original price but chose this system so they could be at a later date if desired.
Have made contact with Baxi and they have confirmed that it is normally fitted on combination boilers but will also work with there system 600 and I believe this will also work with there outside temperature control sensor set up as well.
This is what last email is about sorry the Baxi 600 system works with it. It is normally fitted on combination boilers.
