Some interesting motherboard tests of the VRM power stages here.
Looks as if you really get what you pay for:
and at the cheaper end:
The only thing I would say is a lot of the reviewers test on open benches where the air flow is non existent so some of the temps are a tad high compared with in a half decent case with air flow.
yeah you do get what you pay for, worth keeping in mind that you can only test what is in front of you all these boards are mid-tier boards or in case of godlike mid-tier with bells, there are no OC class boards in this test from Asus, MSI or Asrock.
Here's more of reasonably priced boards.and at the cheaper end:
Little airflow won't make those 100C running VRMs good.The only thing I would say is a lot of the reviewers test on open benches where the air flow is non existent so some of the temps are a tad high compared with in a half decent case with air flow.
And that's the big problem in lots of more expensive supposedly better consumer products:First thing I've done was replacing the VRM's thermal pads from my Asus X570-f to some decent ones. The temperature drop more than justified the 7 quid spent.
Annoying is the fact that most of the motherboards, regardless if it's a rat's-foot version or the bee's knees version, will have some cheapo thermal pad.
Decent airflow will make a big differenceHere's more of reasonably priced boards.
Install hardware info to check VRM temps. I suspect under normal use and in a well vented case you will be fine.What worries me is that i have a msi gaming plus mobo, although its only paired with a 3700X so will be running colder. I assume mine shares the same VRMS with that board, is 100 degrees bad on VRMS, i'd of thought they'd be able to take it.
