So am I getting drawn into the whole 'ASUS ROG Strix' thing where I think they are a better brand?
Asus are no better than the others, often worse. Despite being way more expensive.
Wow so many replies and help. It’s great to see so many concluding that getting two cards is better than throwing it all into a 2080ti.
I am thinking this now -
https://www.overclockers.co.uk/asus...ddr6-pci-express-graphics-card-gx-43h-as.html
and with the £105 off it’s only £545. Thoughts? I can’t see the difference between the 2080 Super and the one above to warrant the price difference.
I will eventually get a higher resolution monitor.
£545 is too much money for a 2070S when you can buy a Powercolor 5700XT dual fan for £399 in UK.
Thats £150 you can invest on other parts of your system, even a better Freesync monitor.
Is a 5700 flashed to XT really a capable 4k card? I was under the impression that 4k was just a bit too much for it? A very capable 1440p card but doesn't quite have the 4k grunt requiredHe doesn't understand the Radeon cards which is a shame. He could buy the RX 5700 and flash with RX 5700 XT BIOS.
Spend smart, save a lot and upgrade to something really good.
My basket at Overclockers UK:
spend the extra £140 and get a 2080 super.
Because their fully automated GPU assembly makes worse cards than the error prone human using competitors?
go with a 5700 XT over a 2070s. small gains not worth the significant increase in cost. The powercolor red devil is the card to get.
Dude, a 2070$ is not worth £650 or anything close to that... £500 max! Your call in the end, but if money is not an issue to be wasteful like that, might as well grab a 2080 Ti for £300 or so more? At least you get something for the extra money then no?Right. I have just had a go at iRacing and it averaged at 89fps. With my 970. I've also found out that RF2 works really well on high settings with a 2070 super (albeit not on Ultra, but I've been told that you'd probably need 34 2080ti's to do that!)
So, budget wise, I am going to go for the 2070 Super. And after speaking to the wife, she said I can do this again in 3 years. So every 3 years I will just do this.
So, what 2070 Super for about £650 maximum (that's just for budget) would do me the best. I don't want to worry so much about temps. I don't plan to Overclock myself as I have no idea about overclocking.
