Dying GTX 980 what should I replace with?
26 May 2006
Edinburgh
I'm just not sure if I should pull the trigger on a complete new build. Finances are a little tight.
My GTX 980 is dying a slow death. Artifacting when booting windows. Takes 2-3 boots before monitors will go on. Strange performance dips in games that were not an issue before etc.
Is there a budget card I can throw in for even better performance below £150 or should I really be thinking about a complete new build?
Current build:
  • Mod 1150 ASUS Z97-A ATX Motherboard
  • Corsair CMY16GX3M2A1866C9R Vengeance Pro Series 16GB (2x8GB) DDR3 1866Mhz CL9 XMP Performance
  • Intel Core i5 4690K Processor (3.5 GHz, 6 MB Cache, LGA1150 Socket)
If finances are tight, just get a used 980 Ti from the members market. Nice little boost from that normal 980 and it's still a very capable card!
If the budget is around £150 then a few 980's are on the MM for around £120, seem to be still very capable strong cards
Have you cleaned the card out and repasted? I know it's unlikely to be the issue but it's free to try...
I've bought a 2nd hand gtx 980 on the MM. I can play about with this current card once the spare arrives. It's so unstable I don't want to **** with it before then.
Second hand G1 1080 was a huge upgrade for me. Put it under water and overclocked the gibbons off it. Very happy.
They’re quite expensive compared to 980s on the MM though, and I don’t think I’d have been happy without a heavy overclock.
